Pls help
Old Oct 24, 2020 | 05:38 AM
Skexay's Avatar
Infiniti g35 sedan 6mt
Pls help
So I bought a 07 g35 sedan 6mt and ever since Ive bought this damn car Ive had nothing but problems first the ac compresser went out then the car had this weird uncomfortable shake to it my father said probably needs a clutch so he said you can drive it for a few hundred more miles the next day I was just cruising and the whole car was smoking there was a whole puddle of oil underneath the car I shut off the car and got it towed back home just to find out there oil everywhere underneath the car on the tranny the catalytic converter everything and I cant locate this leak I will upload a few pics.
Old Oct 24, 2020 | 12:16 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Just start the car and look for the oil leak with an inspection mirror and a flashlight. With that much oil it should be obvious, don't let the crankcase run dry.
Old Oct 24, 2020 | 10:33 PM
Skexay's Avatar
The thing is that its going everywhere people are telling me rear main seal is that common?
Old Oct 25, 2020 | 12:04 AM
cleric670's Avatar
BANNED!!!
Let me repeat what I just said.
WHERE EXACTLY is the oil coming from, with that much oil it should be VERY OBVIOUS because it's going to be pouring out of something somewhere.
Old Oct 25, 2020 | 12:08 AM
cleric670's Avatar
BANNED!!!
I'm not trying to be an ******* about it but you need to TROUBLESHOOT THE PROBLEM. There's a lot of reasons a car can be dumping a lot of oil.
You could have a hole in the oil filter
You could have a hole in the oil pan
You could have blown a big chunk out of a valve cover gasket
You could have thrown a rod and have literally a hole in the side of the engine
You could have a loose drain plug
You might have a bad RMS?
Get an inspection mirror and a flashlight and look to see EXACTLY where the oil is leaking from. Don't just automatically assume that it could be something, especially not something as labor intensive as a RMS, troubleshoot that ****!
Old Oct 25, 2020 | 05:46 AM
telcoman's Avatar
Veteran: Army
And a loose oil filter or a defective oil filter gasket?
Old Nov 4, 2020 | 03:05 AM
Skexay's Avatar
Fixed it
Just like I suspected you need up being RMS but now my car is making a weird rattling sound my mechanic is telling me it has rod knock and that I need a new engine. When the car is idling it doesnt make the sound only when I rev the engine it makes that sound I suspect the catalytic converter or heat shield anyone else have this problem?
Old Nov 7, 2020 | 03:10 PM
cleric670's Avatar
BANNED!!!
Take a video of it with the hood open and try to get a good capture of it making the sound.
Rod knock is pretty unmistakable and you can usually tell from a video.
Old Nov 7, 2020 | 03:19 PM
telcoman's Avatar
Veteran: Army
Why did you purchase the vehicle without having it inspected by an Infiniti dealer?
sectox
Nov 12, 2013 09:28 AM
remedy00311
Mar 9, 2012 04:01 PM
G-MAN (CANADA)
Canada
29
Mar 11, 2011 08:49 PM
rpm06g35
SFL G CLUB
Sep 12, 2008 10:32 PM
G35CDUCK
Dec 31, 2006 12:10 PM
