Faint Rattling Noise from Front End in Acceleration
Old Mar 24, 2022 | 02:44 PM
04vq35sdn's Avatar
2004 G35 Sedan 6MT
Exclamation Faint Rattling Noise from Front End in Acceleration
2004 G35 Sedan 6MT 108,000 miles: I have a faint rattling noise from the front end of the car that occurs only during acceleration mainly between 2-3k RPMs. It sounds like a faint metallic wheel of fortune or bike wheel with something in the spokes. It is nonexistent when in neutral revving the engine, only happens in gear accelerating in that 2-3k range. There is no strange noise on startup either. I don't think it's a heat shield because it is inconsistent. It doesn't sound nearly as loud as any of the failed timing chain tensioner videos I have seen and is a higher pitch. Pads, rotors, and calipers are new, so it isn't the brakes. If anyone has an idea of what it could be, any advice is much appreciated.
Old Mar 25, 2022 | 07:04 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Does it happen only in gear, only in neutral? Only when the clutch is pressed in or out?
My guess would be something failing on the stock dual mass flywheel if you're confident it's not an exhaust rattle.
Old Mar 25, 2022 | 10:47 PM
04vq35sdn's Avatar
2004 G35 Sedan 6MT
It only happens when in gear and the accelerator pressed, not with the clutch pushed in. Someone told me it could be the catalytic converter because my exhaust is kind of smelly and my car idles low around 200 rpm. It's just strange how it comes and goes, today I drove 40 miles and didn't hear it once.
2006G356mtCoupe
Jul 25, 2025 09:32 PM
Michael Elam
Jul 13, 2016 02:07 AM
smokedhen
Nov 12, 2007 12:20 PM
dennyduong
Jul 16, 2005 11:50 AM
