VQ Oil leaks
Old Jun 28, 2022 | 01:16 PM
Kbayless's Avatar
Infiniti G35 Sport Coupe
VQ Oil leaks
Hi I just purchased a 2005 Infiniti G35 coupe with 200k miles, what are the typical gaskets that will leak oil at its age. Thank you!
Old Jun 28, 2022 | 07:40 PM
Urbanengineer's Avatar
timing chain galley gaskets and the rear main seal.
Old Jun 28, 2022 | 09:59 PM
G2B35AGN's Avatar
And piston rings!
Old Jun 29, 2022 | 07:07 AM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Not quite replaceable gaskets on their own, but the spark plug tube seals built into the valve covers are known to "leak".
Old Jun 29, 2022 | 08:20 PM
G2B35AGN's Avatar
Yeah I just didn't want OP to be surprised when it still consumes oil after he gets rid of all the external leaks....
You want to check your oil with every fill up until you know where you stand. Adjust frequency once you got it figured out.
Old Jun 29, 2022 | 11:21 PM
Kbayless's Avatar
Yeah I know the vqs are notorious for burning oil. Will it burn off oil with regular driving or just when you’re running it hard?
Old Jul 1, 2022 | 10:52 AM
G2B35AGN's Avatar
Once it starts, I suspect even regular driving will eat oil.
Aevum89
May 12, 2021 08:05 PM
la-law
Mar 29, 2019 04:20 PM
Tylko Kazik
Apr 10, 2015 01:45 PM
options13
Jul 24, 2012 05:26 PM
MadBoost23
Apr 18, 2012 01:06 PM
