05 g35 coupe crank but no start
Old Apr 25, 2024 | 07:57 PM
ethannnnnn's Avatar
g35 stock except test pipes and hr injectors
Originally Posted by coffeysm
Did you do the starting fluid or carb cleaner test? Try running it with an alternate fuel source and did you check the original camshaft you took out to make sure it's actually bad? You'd need an oscilloscope to get the correct reading, but I think you can do some resistance checks on it.
Ik this is old but what exactly is this test. my car won’t start either it cranks then dies almost instantly we tried putting gas straight in the tb and she starts and will rev fine until the gas is taken away what would that mean
Old Apr 25, 2024 | 10:48 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Empty gas tank, failing fuel pump, etc.
I'd definitely start by just adding 1 gallon of fresh fuel to the tank, these cars are notorious for the gas gauge failing and showing 1/2 tank when you're actually home dry empty.
Old Apr 25, 2024 | 11:34 PM
ethannnnnn's Avatar
I have and really wish it was that I’ve taken the hardline off right behind the pressure regulator and it gets gas when i crank it over so it gets gas
kodiak341
Jan 1, 2023 12:45 PM
LegacyG35
Drivetrain
Jun 30, 2020 01:16 PM
b_dupy
Oct 12, 2016 09:04 AM
yosip1115
Mar 25, 2013 08:43 PM
ImPoppi
Jul 24, 2012 10:58 PM
