Which BCM do I need (2005 g35 coupe MT / RevUp) engine)
Old Sep 19, 2023 | 05:20 AM
peenutz's Avatar
Hello,
I have a 2005 Infiniti g35 coupe (MT & RevUp)
My car wont crank and was told that I need a new/used BCM.
According to my VIN# JNKCV54E85M415051
They say I need these BCM #s
284B1-AC700 or 284B1-AC764
But my current installed (BAD) BCM part # 284B1 AC361
According to the forum searches it says to use the same part # as what is installed. But everyone who looks up the VIN said I need the AC700 or AC764 part.
Can anyone help which route I should go? I only found one AC361 on ebay and the seller said it wont fit according to his VIN check.
Thanks
J
2005 Infiniti g35 coupe (Base / 6speed MT / RevUp engine - NON-Brembo)
Old Sep 19, 2023 | 03:22 PM
peenutz's Avatar
Update
I called Infiniti and they said the BCM is based on the part# associated with my VIN.
And according to my VIN# JNKCV54E85M415051 Infiniti says I need BCM 284B1-AC700
They also confirmed that a vehicle locksmith "should be able to program the new BCM". Used part coming by EOW, so fingers crossed I can get G35 driveable again.
Here is the link to the Infiniti Parts site: https://www.infinitipartsonline.com/ Good resource for OEM parts.
Thx!
Old Sep 23, 2023 | 01:01 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The AC700 is probably just a newer revision of that part, if Infiniti told you to use that one based on their VIN search then I would trust them.
EDIT: After a little more research it appears this BCM is indeed an updated revision designed to fit all 2004.5-2006 G35 models (coupe and sedan) equipped with an automatic transmission. Not sure if it interchanges with the 6MT or not.
G35rattlecanned
Aug 26, 2020 09:00 PM
malin
Engine - Complete Motors
14
Sep 3, 2017 04:20 PM
onevoice
Dec 7, 2011 03:19 PM
KPierson
Archived Sales
18
May 28, 2009 03:47 PM
Ray99
Dec 27, 2008 06:13 PM
