Service engine light after 75mm TB & Spacer instal
Old Feb 21, 2024 | 06:08 PM
75mmAlex's Avatar
G-35
Started engine after 75 mm throttle body and 5/16 spacer instal. I also enlarged the throttle body port to 76mm and smoothed and polished out upper and lower plenum. After running for ten minutes idle was still high about 1200 RPM. I did a ECU reset And it cleared the light but came back ten minutes later And idle still high. Does anyone know what I should do next. I haven't checked the engine code yet,
Old Feb 27, 2024 | 11:19 PM
Urbanengineer's Avatar
I would check for an air leak. Did you forget your gasket between the upper and the lower plenum?
Old Feb 28, 2024 | 01:13 AM
75mmAlex's Avatar
G-35
Thank you for your response on that I did check for vacuum leaks as well. However, I did an idle
relearn Which solved the high idle issue. I also did a throttle body. Positioning relearn. Then I cleared my codes.The service engine light have not returned after a hundred miles. The upgrades have really helped the performance of the engine, mainly the mid and upper range. My 0-60 time went from 7.3sec. to 6.8 but the mid to higher range is where I can really feel the diffrence. Hopefully this will help others. I found the relearn procedures on YouTube.
Old Mar 5, 2024 | 09:05 PM
Glad you figured it out.
Old Mar 6, 2024 | 11:53 AM
seymore4's Avatar
m56
Now you need a tune!
Here's a link to the relearns in case anyone else needs them: https://uprev.com/wp-content/uploads...-Functions.pdf
solista
26
May 21, 2012 11:35 AM
azt108
Mar 14, 2010 12:47 AM
nibble
Apr 14, 2009 09:00 AM
geesteezd
Intake & Exhaust
Apr 21, 2008 12:43 PM
brianyun
14
Sep 19, 2007 11:03 PM
