code p0303 HELP
Old Mar 21, 2025 | 09:02 PM
matt11g35's Avatar
code p0303 HELP
I have this code. I already moved my coil to another coil and the code didn't go to another cylinder, so it's not the coil. I changed all my spark plugs about a month ago, but I removed the one from cylinder 3 and put it in another cylinder and the code didn't go to another cylinder either. I also changed the injector and the problem still persists. The car feels like it's having a misfire and my exhaust makes small popping sounds and when I roll down my windows the car revs lower. Please help.
Old Mar 22, 2025 | 10:40 PM
srv2nv's Avatar
G35 Sport
What spark plugs did you use, and where did you buy them? Amazon and Ebay are notorious for knock off NGK spark plugs.
Old Mar 23, 2025 | 06:26 PM
matt11g35's Avatar
I just changed the spark plugs to NGK iridium ones, but the smoke and popping still persist.
Beaverhunter121
Jul 12, 2021 08:53 PM
IVAN S.
Oct 4, 2020 10:34 AM
Cesar023r
Jan 7, 2013 12:56 PM
Gossmerjr2
Oct 26, 2012 04:03 AM
High3nd_SD_g35
11
Jun 16, 2008 04:01 AM
