Hawaii Honolulu
tuning
Old Sep 11, 2008 | 11:51 PM
fkneh's Avatar
tuning
where are u guys getting ur cars tuned and what are u using
i want to pick up 5/16 spacer and intake and have it tuned
what are the costs for the software and tuning
Old Sep 12, 2008 | 12:04 AM
momonaboy's Avatar
when i get my 5/16th spacer and MREV2 im going to tune my car with this company called technosquare. they are located in cali. all you do is send them your ECU with an form of what mods you have. heres the link http://www.technosquareinc.com/
Old Sep 12, 2008 | 04:35 PM
GZire's Avatar
IMHO it's not worth getting a reflash only for a spacer install.
Old Sep 13, 2008 | 03:00 AM
momonaboy's Avatar
just with my test pipes, nismo CAI, and a kinetix plenum. my car was running lean, and the RPMs during idle would ALMOST stall, never did though. but i sold the kinetix plenum and am getting the motordyne 5/16th spacer and MREV2 lower collector, so i expect the same results. so im going to send my ECU to technosquare and order my parts same time. on a side note i heard that re-flashing the ecu even when your car is stock makes noticeable gains. still better to wait till you get a couple parts before you flash.
Old Sep 19, 2008 | 08:47 PM
FargoG35's Avatar
how much to flash? Will the 5 /16 Iso-Thermal Spacer fit on the 07 as well. One last question... K/N or pop-charger?
Old Sep 19, 2008 | 09:22 PM
jdm-v35's Avatar
flash is usually about 700
Old Sep 19, 2008 | 09:23 PM
TonyG35DG's Avatar
Technosquare flash is about $500, not worth it with just the 5/16 spacer.
Old Sep 20, 2008 | 12:23 AM
halmech's Avatar
I haven't installed the spacer or MREV2 yet, but aren't you supposed to do the proceedure to reset the ECU afterwards. The ECu would then adjust to the new parameters after driving around a few or 30 miles.
Old Sep 20, 2008 | 12:37 AM
TonyG35DG's Avatar
The G's ECU is weird in that it compensates air/fuel mixture of the new mods and tries to bring it close to factory spec, so installing breathing mods sometimes mean loss of power somewhere in the power band. My car actually feels slower in the low end after all the mods (did the ECU reset each time), waiting for Tadashi @ Technosquare to come back on the 22nd to call them about having my ECU flashed. Many people on the forum claim it's the best bang for the buck mod they've done because it unleashes the power the mods are supposed to provide.
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
Usman Ali
Oct 4, 2015 08:23 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
