Hawaii Honolulu
Stance gr+
Old May 19, 2010 | 11:52 PM
Gtrpnoyracer's Avatar
Stance gr+
oem/true or pro? which drops more and what you guys recommend and what spring rates would you use for someone who doesnt want to feel everything on the road (potholes, sharp speed bumps), you guys know what i mean
okay lmk
Old May 20, 2010 | 01:03 AM
Chuck D's Avatar
here is the link to the spring and coilover thread all the info you could ever want.
Old May 20, 2010 | 02:54 PM
oh yeah i seen it but i just wanted to get preference from you guys who have experience with coilovers and which one drops lower.
Old May 20, 2010 | 08:38 PM
Chuck D's Avatar
Ah yeah i think all of stance coilovers will drop you to the frame if you want. I know a lot of the norcal guys are running them. not sure who in hawaii has a set.
Old May 20, 2010 | 10:15 PM
636Racer's Avatar
senjen had a set on his G35. As far as I know, on the performance side Stance has been known to be pretty stout and pretty aggressive - not so much as JIC or Tein. Personal preference i would go 10f/8r, 0 preload adjustment and med damping rate to start off with. I believe with Stance you can adjust the height separately, just make sure you know how much rebound you're getting and adjust the preload and damping rate accordingly.
Old May 20, 2010 | 11:09 PM
oh okay. so i'm planning on running stance gr+ true type rear but as far as spring rates, the guys from stance told me 12f/5r is what's in it already, is that good as in ride quality? and the 10f/8r spring rate that you recommend, is the ride pretty comfortable for daily driving and wouldnt bottom out?
Old May 20, 2010 | 11:43 PM
636Racer's Avatar
The front will be pretty stiff...12/5 doesnt sound bad for everyday driving, the front will be on the stiffer end, just lessen the damping from midway. to me it would sound wierd to have your front damping settings lower than the rear, nothing wrong with it either...just sounds wierd. but in AutoX, 12/5 sounds ideal.
Old May 21, 2010 | 07:02 PM
ak808's Avatar
12/5 is for the inverted type/true coilover. If you want factory location in the rear then I think it goes to 12/10ish.
Old May 22, 2010 | 02:07 PM
oh yeah i heard about that. i want to drop lower so yeah i might just request different spring rates with my true type rear
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
joeslates
Sep 11, 2015 11:19 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
