Hawaii Honolulu
I Hate The Vq Engine
Old Jun 5, 2005 | 08:02 PM
james731's Avatar
engine
i guess now there airing to hear from infiniti of america about replacing the engine and ill find out this week
Old Jun 6, 2005 | 02:54 AM
sen_jen's Avatar
Meatshake Enterprise
good deals. i wish you the best. keep us posted.
Old Jun 6, 2005 | 03:13 AM
MikeyMike's Avatar
Rollin On Dubz
My engine has about 26k on it, and thank god I haven't had any problems. Your car might just be a lemon and fall under the lemon law. I'm in California and the Lemon Law in this state is if the car has a major failure 3 times, you are entitled to a new car.
Good Luck!
Old Jun 6, 2005 | 03:56 AM
jas168's Avatar
no problem here.......i think it could possibly be the internet that makes problems much larger than it actually is....
Old Jun 6, 2005 | 04:10 PM
beangrower's Avatar
Originally Posted by james731
after my car being in the shop for 3 days so they could figure it out and take pics for infiniti of america to see what they want to do, i drove it a half of a mile before haveing to take it back because of strange smells, noises, power loss and it didnt steer right, they also replaced my radio that had some problems, with a radio that didnt work at all! how are you going to give a customer his car back in worse shape than he droped it off in?
i think i was there when you were at infiniti. i was at the parts dept ordering my a/c line at around 430ish. i was over hearing someone talk about a jacked up stereo or something like that. or maybe it wasn't you.
Old Jun 16, 2005 | 01:56 PM
whyjay91's Avatar
Took my coupe in for some sort of chatter when cold. Infiniti said I had about 2.5 quarts of oil in it. WTH!? I changed the oil about 3k miles prior with royal purple synthetic and a wix filter. I drive it aggressively on occassion but nothing too crazy for a 6spd sport coupe. Fortunately the check oil light hadn't been on yet.
Anyway, I'm having infiniti complete a full scrub/flush of the motor and refill with synthetic blend and a nissan filter.
Anyone else have this happen?
Old Jun 17, 2005 | 10:09 PM
G35TRex's Avatar
seems like u got a lemon, i luv my vq engine !!!
Old Jun 18, 2005 | 12:08 AM
650Coupe's Avatar
YUP. VQ is sweet. Just changed oil and K&N filter installed. No probs here.
Old Jun 18, 2005 | 04:09 AM
grizzly's Avatar
changed my oil @ 1700 miles-- put in ~4.5 quarts of dino.
just checked, and the level is good @ 2300 miles.
kinda off topic, but the dip stick in our VQ sux donkey *****! i'm wonderin if the Z-tube improves clearance any?...
James, hope they eventually find out why your engine loses/burns excess oil
Old Jun 18, 2005 | 07:53 AM
DHCrocks's Avatar
approaching 19k on mine and no oil problems yet. I did a change a 3k and then I switched to Mobil1 at 5k and do a change every 5k using a Mobil1 filter.
I only checked the oil level a couple of times, but it's to dang hard. even if you wipe the stick you can't read the fricken thing cause it's all smeared with oil. When I do my change it fills up the recycle box, so I'm assuming that I've still got 5qts in there.
btw grizzly our car takes 5qts.
Old Jun 18, 2005 | 04:50 PM
grizzly's Avatar
Originally Posted by DHCrocks
our car takes 5qts.
i better fill in the rest!
i also need to read the service manual better:
drain & refill w/ filter change = 4.7 liter (5 fl qt , 4.125 Imp qt)<-- WTH is Imp?
thanks for the heads up!
Old Jun 19, 2005 | 07:16 AM
ShikoKaon's Avatar
Originally Posted by grizzly
: (5 fl qt , 4.125 Imp qt)<-- WTH is Imp?
Imperial Quarts (Brittish measure) if I'm not mistaken...
Old Jun 19, 2005 | 08:51 AM
nouse4aname's Avatar
Wow Shiko! you so smart
Old Jun 21, 2005 | 05:48 PM
james731's Avatar
engine
ill take my car in next week wehnits out of the body shop, i got hit to. ill keep you all posted but they say it will take about a month to do the work.
Old Jun 21, 2005 | 06:12 PM
  #30
sen_jen's Avatar
damn, no wonder i don't see you on the road going to work. where did you take your car??
