- WTB: 1 piece aluminum driveshaft
- FS: OS Giken twin plate clutch TR2A
- FS: New Whitline Diff bushings
- FS: New OEM Belts
- FS: JWT G35 Clutch/Flywheel Combo w/ Free Parts 2003-2007 Coupe 2004-2006 Sedan
- FS: OS Giken Triple Plate Clutch
- FS: JWT Clutch and Flywheel BNIB
- FS: Nismo Finned Diff Cover - Brand New
- FS: RJM V2 Adjustable Clutch Pedal Assembly for 350Z/G35
- FS SoCal: TWM Short Shift Kit
- WTB: Z1 aluminum driveshaft
- FS NorCal: RJM Clutch Pedal Assembly
- FS MidWest: Torque Solutions Trans Mount
- WTB NorCal: New clutch kit
- FS: Torque Solutions Transmission Mount
- WTB SoEast: one piece aluminum driveshaft
- WTB: 4.08 gears or whole pumpkin
- FS: RPS Cyn-R-G Flywheel/JWT Clutch
- WTB: 05 Auto Transmission AWD
- FS: Some 6 Speed Conversion Parts
- FS SoCal: 2005 350z 6-Speed transmission for sale
- FS: Trans Cooler with thermostat, filter
- FS SoCal: OEM Flywheel, Pressure Plate, Clutch - 2005 Sedan
- FS NorEast: Ngk Iridium Spark plugs (4469)
- WTB: carbon fiber drive shaft
- FS: SPL Solid Diff Bushings NEW IN BOX
- WTB: OS Giken Super Lock LSD
- FS: WTS: 2800 Stall Edge Torque Converter
- FS: Kinetix Camber Kit
- WTB NorCal: NISMO Clutch, Flywheel Pressure Plate
- FS NorEast: 350z shifter
- FS: OS Giken triple plate clutch
- WTB NorEast: Transgo shift kit
- WTB Canada: G37 3.69 diff(carrier)
- FS: RJM Clutch pedal bracket V2 BNIB
- FS: New JWT clutch,Newest RJM Performance Adjustable clutch Pedal,Split Second ECU
- WTB NorEast: 3.5 vlsd awd 05
- FS NorEast: 6MT Driveshaft
- FS: Vlsd 3.5
- FS: Genuine Nismo GT Hard Rubber Shift Knob
- FS SoCal: OS GIKEN - Twin Disc Clutch & Flywheels
- WTB: Lightweight/Aluminum Driveshaft for 5AT
- FS: Newly rebuilt 5AT (BUILT) w/ TB + Edge TQConverter
- FS NorCal: Torque Solution Transmission Mount
- FS: NEW Nissan / Infiniti Axle Stub 38220-AR011
- FS NorEast: 3.5 VLSD differential and SPL solid bushings
- FS: 2004 OEM G35 coupe shifter
- WTT: 3.5fd LSD for 3.7 Differential
- FS NorEast: Clutchmasters stage 2 Kevlar clutch and SPEC aluminum flywheel
- FS: Carbonetic TRIPLE Carbon Clutch **very light use
- FS: BNIB Carbonetics Triple disk
- FS: 4.08 gears and housing
- FS: Brand new Exedy OEM Clutch and slightly used Flywheel
- WTB: 6MT Driveshaft
- FS: 1 New JWT Clutch, & 1 used JWT clutch/new disc& JWT Flywheel with NEW friction plate!
- FS: ACT Clutch and Flywheel
- FS: ACT HDSS Clutch kit
- FS: Southbend DXD-B and UR Flywheel
- WTB: AT to MT swap parts (ALL)
- FS: ACT 16lb flywheel & HD clutch/pressure plate 7k mile
- FS: Nismo Flywheel Brand New!
- WTB SoCal: 03 G35 Coupe Auto Trans Valve Body or 03/04 Transmission
- WTB: 4.08 or 3.9 final drive
- FS: Competition Twin Disk Clutch (Only 4k miles)
- FS: CD009 + OEM Clutch (only 27k miles)
- FS Canada: Passenger axle stub from 6mt diff - Needed to upgrade a 5AT differential
- WTB: Flywheel
- WTB: 06 G35X front passenger side axle
- WTT: 3.3VLSD for 3.5VLSD
- FS: 6mt 03-07 Z1 G35 Platinum Series Aluminum 1-Piece Driveshaft
- WTB: CD009 6MT + Drive Shaft
- FS: JWT Lightweight Clutch Setup (CHEAP!)
- FS: OEM G35 Flywheel 40k miles CHEAP
- FS SoCal: ACT clutch and JWT flywheel
- WTB: 04 G35 coupe auto trans
- WTB: LSD, Twin Disk Clutch,
- FS: Competition Stage 2 Clutch
- WTB: flywheel for 04 coupe
- FS NorEast: Stock Clutch
- FS SoCal: Brand New ACT clutch
- WTB: Spec Clutch ss
- FS: NGK Iridium IX SPark Plugs (8)
- FS: JWT Flywheel for G35 VQ35DE
- FS: B&M Short Throw Shifter
- FS NorEast: Clutch Bracket & Hardware off g35 Coupe RevUp
- WTB: Transmission oil cooler for 5AT
- FS NorCal: G37 vlsd rear differential 3.69 fd
- FS: JWT clutch and flywheel
- FS SoCal: Differential: 3.3 VLSD
- FS: Competition Twin Disc clutch
- FS: RedLine Transmission Fluid MT-85 (1QT)
- WTB NorCal: Need OEM Clutch set
- FS: Carbonetic Twin Clutch Kit with Flywheel
- WTB: exedy OEM clutch kit
- FS: 2006 G35 Coupe Clutch & Flywheel
- FS: Jwt clutch and flywheel and Fidanza flywheel 03-06
- FS: Act Streetlite Flywheel
- FS: 2008 VQ35HR 350z OEM Clutch & Flywheel w/35k miles
- FS: 2008 OEM 350z VLSD w/3.5FD w/35k miles
