PDA
View Full Version : Drivetrain
Pages : 1 2 [3] 4 5
  1. FS: 3.3 VLSD Diff
  2. FS: Stillen Engine Damper Brace -New in Box
  3. FS SoCal: Auto Transmission and OEM drive shaft
  4. WTB SoCal: 2005 AT valve body assembly
  5. FS: CD009 and F1 clutch/FW
  6. WTB: ANY 6 speed
  7. FS: Lightweight AASCO/JWT/Stillen Flywheel
  8. WTB: OEM Flywheel
  9. FS NorCal: *Brand New In Box Exedy OEM Clutch Kit and ACT Streetlite Flywheel* PICS INSIDE.
  10. FS: OEM transmission pan
  11. FS: Stock OEM 6MT shifter
  12. WTB SoEast: CD-009 Manual Transmission
  13. FS NorEast: Sikky 350Z/G35 Wilood Master Cylinder Conversion Kit
  14. FS: OS Giken Superlock LSD
  15. FS: OS Giken STR twin disc clutch
  16. WTB: OEM Clutch and pressure plate
  17. FS: HD-2 valvebody upgrade
  18. WTB: Tripple disk
  19. FS SoEast: 4.083 Final drive Vlsd pumpkin & 3.35 VLSD pumpkin
  20. FS Texas: RJM Clutch Pedal & Oem Aluminum Pedals 6MT
  21. FS: ORC Ogura Racing Clutch (NIB)
  22. FS NorCal: 3.69 fd vlsd
  23. WTB: front right axle for 04 g35x
  24. FS: OS Giken Twin Plate Clutch used for 4000miles
  25. FS SoEast: G35 OEM shifter
  26. FS: 5AT Trans, Interior, 6mt swap parts and other goodies.
  27. WTB: Twin Disc Clutch
  28. FS: 03.5 5AT transmission. LEVEL10 Rebuild kit
  29. FS SoCal: G35 350Z automatic transmission w/Transgo shift kit
  30. WTB: TWM Performance Short Shifter
  31. FS: 3.3 (non-LSD) pumpkin off 06 g35 coupe
  32. FS: RJM Performance A.F.P Clutch Pedal System
  33. FS: B&M Short Shifter
  34. FS: Complete 3.3 non-locking differential
  35. FS: Complete 3.5 VLSD differential
  36. FS Texas: SGP Solid Motor Mounts & OEM '04 G35 Clutch/Flywheel
  37. FS NorEast: auto 05 coupe lsd 3.3fd pumpkin
  38. FS: Clutch Pedal Assist Spring for 6MT
  39. WTB: Rogue Short Shifter
  40. FS: 04 infiniti g35 6mt tranny,driveshaft,etc
  41. FS: B&M Short Shifter
  42. WTB: OEM Flywheel
  43. FS: Spec clutch & act prolite flywheel & oem clutch & flyewheel
  44. FS: 4,083 FD, cusco RS lsd pumpkin and more
  45. FS: OEM clutch master cylinder 30610-CD00B
  46. FS: Dss pro axles
  47. WTB: 2003 G35 Sedan AT transmission
  48. WTB: LSD for RWD Sedan
  49. WTB: Stillen or TWM short shifter
  50. FS: Stock Clutch, Flywheel, and random stuff.
  51. FS: Short shifter ? Stock clutch and flywheel
  52. WTB: 3.3vlsd
  53. FS NorEast: 2005 5AT and 3.3VLSD
  54. FS: Transgo VB kit A/T
  55. WTB: driveshaft
  56. WTB: Lightweight Flywheel.
  57. WTB: 350z/G35 BASE OPEN DIFF AXLE STUBS
  58. WTB: Rogue Engineering Short Shifter Kit
  59. FS: OEM Infiniti G35/Nissan 350Z Clutch Slave Cylinder
  60. WTB: VLSD axle shafts
  61. FS: 2008 350z OEM 3.5 Final Drive
  62. FS SoEast: 350z / G35 Nismo LSD - Pumpkin ( diff ) $550
  63. WTB: Automatic Transmission 05
  64. FS: jwt heavy duty clutch and pressure plate
  65. FS: Exedy oem replacment clutch and f1 flywheel
  66. FS: Forged solid motor mount and solid transmission mount
  67. FS: G35 Transgo Shift Kit A/T
  68. FS NorCal: OEM Flywheel, Pressure Plate, and Throw Bearing
  69. FS: OEM Clutch, CD05 tranny
  70. FS: SouthBand Stage 5 clutch & ACT flywheel combo. cheap!
  71. FS: 2008 Nismo 350z OEM VLSD
  72. FS: 12qts of Amsoil Signature Series 0w30
  73. FS SoEast: OEM '06 Shifter, Brand New Comp Clutch 2-350Z-STU Flywheel, Rad Cap
  74. WTB: Wtb oem clutch for 05 g35
  75. FS: Automatic Transmission Fluid Matic-S
  76. FS NorCal: Brand new OEM clutch kit and ACT flywheel
  77. FS: 07 NEW Nissan Valvebody with Trans-go Installed
  78. WTB: want to buy short shifter
  79. FS: Stock air box and resonator
  80. FS NorEast: ACT Xtream Clutch Kit
  81. FS: Z-Speed under tray-Aluminum Undertray
  82. FS: Rogue Engineering Short Shifter
  83. FS SoEast: ACT clutc/lightened fly wheel and b&m short shifter
  84. FS: **new** nismo flywheel
  85. FS SoCal: TransGo Performance RE5R05A-HD2 BNIB
  86. FS SoCal: New zero miles CD009 Transmission
  87. FS: stub axles, subframe bushings, open diff, oe clutch
  88. WTB NorEast: OEM Shifter
  89. FS: BNIB Trans-GO ValveBody Upgrade
  90. FS: 4.083 gears nismo lsd motul fluid, nismo dif cover
  91. FS: 3.5 vlsd diff
  92. FS: 3.7 FD Differential w/VLSD and AMS Solid Bushings!
  93. FS: BNIB OEM Nissan/Infiniti VB for 04.5 UP 5AT G35/350z
  94. FS: 4th stage competition fly wheel for sale
  95. FS: 05 OEM 6speed transmission CDO #1 CHeap
  96. FS SoCal: 3.5 Final drive, whole Pumpkin Differential less than 45k miles $250
  97. FS: Stillen Engine Brace
  98. FS: Matic j trans fluid 8qts
  99. FS SoCal: Carbonetic Triple Plate Carbon Clutch - LOW Mileage
  100. FS SoCal: 04 Open Differential *Priced to Go*
