Should I worry about RATTLES from system install?
Old Nov 15, 2005 | 01:18 AM
ScapGF's Avatar
Should I worry about RATTLES related to system install?
Tomorrow I am getting 2 10in DA subs installed as well as replacing the components with DA661's.
Now, should I expect a decent amount of rattling from the trunk, doors, etc...?
If so, how much?
Can it be prevented?
What should I expect?
Old Nov 15, 2005 | 01:27 AM
MikeyMike's Avatar
Rollin On Dubz
You're going to have to Dynamat the hell out of you trunk...and don't forget to put some foam where the rear deck meets the trunk.
Old Nov 15, 2005 | 01:51 AM
ScapGF's Avatar
About how much dynamat is sufficient in this case?
Old Nov 15, 2005 | 02:25 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
If i were you i'd get a dynamat extreme bulk pack. Then lay it out over your whole trunk. I'm doing the same thing to my sedan when i put in my 2 12" alphasonik's. good luck
-GP-
Old Nov 15, 2005 | 12:38 PM
Gee Im Fast's Avatar
You will have rattles, or your money back.
Old Nov 15, 2005 | 05:08 PM
g8tor20's Avatar
FGC's official flip flopper
Thats the nature of the beast I guess.....
Old Nov 16, 2005 | 01:17 PM
G35PhatS4's Avatar
G SQUAD
Turn up the volume...
Yes, the rattles will be much more... "amplified".
Old Nov 16, 2005 | 01:52 PM
Beowulf's Avatar
Do the best you can ahead of time with dynamat, but the rest you will have to work out as they show up. As the car gets older you will get more rattles.
You can shim the problem areas with rubber and foam tape.
Old Nov 16, 2005 | 02:00 PM
G35blk's Avatar
what do you mean by the older the car gets...more rattle?.. is it because of the fact that everytime you bump your system..things get more lose, causing gaps somewhere, resulting more rattles? i doubt the older the car gets..you will get more rattles..it all depends on how you dynamat in the first place.
Old Nov 16, 2005 | 07:13 PM
ScapGF's Avatar
Just got the car back from the install place. Luckily the trunk rattle really isn' that bad. I will probably dynamat the trunk at some point, but for now it isn't high on my list of priorities. But, I DID go ahead and have the doors completely covered in dynamat, making the DA661s I put in there sound great!
Old Feb 22, 2006 | 07:02 AM
Real_G's Avatar
An Army of One...
That is my one fear.. trunk rattle.. Im still up in the air as to add a sub or not... I want clean bass... no rattles!
Old Feb 22, 2006 | 12:55 PM
richie's Avatar
if my panels side panels are rattling, should I put dynomat on the panel that rattles, or put the dynomat on the metal part of the car?
Old Feb 22, 2006 | 09:12 PM
BigSash's Avatar
Get Cascade VMAX. You can buy a bulk pack for a really good price by following the llink on their website. Don't buy it from a dealer, they make a fortune on this stuff!
Old Feb 22, 2006 | 09:14 PM
BigSash's Avatar
http://www.cascadeaudio.com/vmax.html
chinee
Jun 10, 2024 07:48 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
nickmcc123
Aug 20, 2015 03:10 PM
sclair
13
Aug 7, 2015 05:43 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
