What happen if Exhaust rusted!!!
Old Jul 5, 2006 | 06:44 AM
mkn1620's Avatar
I'm going to buy a used exhaust... but it looks like its rusted... i cant tell how bad it is untill he took it off from his car. I call few places... they said as long as theres no leap its all good. some places told me that all exhaust system will get rusted. its just the matter of time.
1. will all exhaust system get rusted?
I was wondering. If it did rusted... and its still in OK condition. how can i prevent from it rusted again? some places sell spray paint with "stop rusted" chemical in there.
2. does it really work?
3. if the exhaust system rusted.. is it bad already? not worth it to buy it?
since i know nothing about the exhaust system, might as well ask around...
4. i wonder if it has a leak or sometime in the future... can i fix it? and how much would it cost?
Hope u guys can help me out!! thx in advance!
Old Jul 5, 2006 | 10:56 AM
G.Ride's Avatar
sometimes they just get some surface rust. Once they rust completely i.e. through the piping,then you will have exhaust leaks. You can have it fixed by going to a shop and having the cut out the deteriorated part and welding in a new peice.
Old Jul 5, 2006 | 11:06 AM
mkn1620's Avatar
wow, kewl, they can do that!
Old Jul 5, 2006 | 11:11 AM
G.Ride's Avatar
yup, it was done to my old car.
Old Jul 5, 2006 | 11:12 AM
Scootch's Avatar
you will be ok..like he said juts surface rust take a sos or steel wool pad n clear her up a bit..also u can spray that rust proofing on there..make usre its heat resistant also..as u dont want to smell burt paint while u drive...i also work at a body shop and this is a common thing
Joe
Old Jul 5, 2006 | 11:25 AM
truplay8's Avatar
THE BATMOBILE
like everyone else said its prob jst the surface is rusted.......the exhaust has to be on the car for atleast 75k miles or more to really rust all the way through
Old Jul 5, 2006 | 11:26 AM
gary c's Avatar
Why would ya.............
Your buying a used exhaust system that has rust on
it.......right? If it's stainless you'll only have rust on
the welds. Most if not all cat-back system are all
stainless......if the one your looking at is rusty look
somewhere else.......like here!
Old Jul 8, 2006 | 12:01 AM
FastIntentions's Avatar
It all depends on what material it is made out of. For example if it is mild steel, it will rust for sure. Stainless steel, that depends on what kind. The two most common are 409, and 304. 409 will rust eventually, but 304 will not. Also you need to see how deep the rust is. Like everyone else said, if it is surface rust then wire wheel it out or with a sos pad. If its deep then you might be wasting your time even buying it. Reason being, you might have to go through more work then it is worth to repair it. If you are looking for a good paint, you might want to look in to this one: dupri color high heat ceramic coated silver. Buy the one that is 1200 degree. I believe the part number is DH1606. This will protect the exhaust system. Hope it works out for you.
Tony
Old Jul 8, 2006 | 02:11 AM
mkn1620's Avatar
wow, these informations are very helpful. thx!!!!
Old Aug 3, 2006 | 09:46 PM
astig_z's Avatar
Is there a difference when buying a used exhaust off a super charged or a turbo charged car? If so, then what do i have to look for when buying a used exhaust off a forced induced car? TIA!
jdubin94
Sep 1, 2015 12:17 PM
Ray Feta
Aug 13, 2015 11:40 PM
Jussaku
Aug 13, 2015 07:13 PM
newg37
Jul 26, 2015 09:32 AM
si_driver
Jul 14, 2015 12:29 PM
