Any Cure for Raspy Exhaust?
Old Sep 12, 2006 | 04:35 PM
da mayor's Avatar
Originally Posted by ratm68
Just got back from exhaust shop, no room to fit the 20" resonator they stock. Either find smaller ones, which are are hard to come by or do the Magnaflow x-muffler. I think that x-muffler would directly replace my current X-pipe nicely and should have plenty of clearance room. Found a vendor that sells it for $75 shipped, not bad.
~Khoa
how can a 20" resonator not fit and i can fit a 22" resonator into my car?
Old Sep 12, 2006 | 04:49 PM
636Racer's Avatar
turbocharge it.
Old Sep 12, 2006 | 07:39 PM
ratm68's Avatar
I already have a custom x-pipe on my Invidia true dual, there's not much space left to run the spacer, considering there are plenty of bends in order to clear obsticle.
~Khoa
Old Sep 20, 2006 | 02:04 PM
ratm68's Avatar
Update, I got the Magnaflow x-muffler installed to replace my x-pipe. This is similar to the one Fast Intention uses on their exhaust. This muffler quiet everything down, almost too quiet . But no more rasp and drone. So hopefully the muffler will break in and will get a lil louder after some uses, as most exhaust does.
~Khoa
Old Sep 20, 2006 | 03:46 PM
C_Lawd's Avatar
~Khoa
Where did you get the Magnaflow installed? Is it now as quiet as stock, but with the Invidia note? I bet that sounds sweet! You gotta let me hear it, mang!
Old Sep 20, 2006 | 05:03 PM
dTor's Avatar
Just FYI, for anybody looking to purchase the magnaflow x-pipe, p/n 11385 (2.25" in/out) or 11386 (2.5" in/out), check your local muffler shop before ordering online. I got mine for $79 + tax from a muffler shop around here. They had it in stock. The cheapest I've seen is on ebay for about $86.
Old Sep 20, 2006 | 07:02 PM
ratm68's Avatar
I got it for $67 shipped!! the $86 is the lowest Magnaflow will allow vendor to list I believe. One vendor suggested you call and i got $67 shipped as a result!!
I got it installed in Glen Burnie at Tony's Custom Exhaust, they're awesome and did it for $50!! It is stock quiet with Invidia note. I think at first it seem more quiet but I think it may be the loudness with the recent TP addition that I forgot what it sounded like before. So hopefully the muffler will break-in and get lil more decibel out of them.
~Khoa
Old Sep 20, 2006 | 10:54 PM
driguez's Avatar
maybe bc his is a coupe and your is a sedan???
Old Oct 22, 2006 | 12:53 PM
ExWRXDriver's Avatar
Has anyone tried welding brackets onto their testpipes to bolt up to the stock bracket that holds onto the cats? I have some rasp and I almost wonder if it's from the exhaust not being held in place tight enough... Also has anyone tried exhaust wrap to help get rid of the rasp?
Old Oct 22, 2006 | 01:49 PM
ISMSOLUTIONS's Avatar
Nope/Yep - they always break, which is why the aftermarket units do not have them. Also - the aftermarket CATS and Resonated TestPipes are about 10lbs lighter PER SIDE - so the bracket is really not needed either.
Rick
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Albanian122
Sep 12, 2015 04:02 PM
