Aem Cai
Old Oct 3, 2006 | 08:37 PM
newbieg35's Avatar
Aem Cai
let me see some engine bay shots of you guys that have the AEM cai installed please
Old Oct 3, 2006 | 08:57 PM
caskyline's Avatar
Former Vendor
These are old pics when I used to have an AEM intake.
Old Oct 4, 2006 | 04:01 AM
Diamond G35's Avatar
can somebody say "heat sink"?
Old Oct 4, 2006 | 01:36 PM
truplay8's Avatar
THE BATMOBILE
stay away from aem cai.......heard you loose power
Old Oct 4, 2006 | 02:19 PM
04Gwhiz's Avatar
is this true? if so what cold air is better?
honestly whats the major difference between cold air and short ram
Old Oct 4, 2006 | 03:12 PM
cato's Avatar
SouthernComfort Moderator
Search, GrassHopper!
Old Oct 4, 2006 | 03:36 PM
caskyline's Avatar
Former Vendor
Please explain.
Old Oct 4, 2006 | 03:40 PM
ISMSOLUTIONS's Avatar
The long and the short of it
Long tube intakes (CAI) will cause you to get the most top end power at the sacrifice of bottom end power.
The shorter units, like the Stillen unit, will give you top end power and not rob you of bottom end power, and likely give a boost in the bottom end as well.
For AT cars - your best off with the short ram styles, as it's really hard to bypass the bottom end without a torque converter.
For MT cars - the best bet is the long tube, like the Injen, as it is far easier to 'slip' past the troublesome bottom end power issue.
The other issue with long tube units, are the possibility of getting water logged, by their placement. The Stillen and PopCharger are the best for overall performance and safety...
Rick
Old Oct 4, 2006 | 05:29 PM
DaveB's Avatar
I must beg the question because your statement above goes against the physics intake runner design. Short runners make higher end power at the expense of lowend torque. Long runner make strong lowend torque at the expense of high rpm power. Long runners draw in large columns of air that stack as it's drawn in creating laminar air flow; however, as the rpms rise, the stacked air creates a turbulance problem and acts as a restriction.
Old Oct 4, 2006 | 11:47 PM
You are completely right, as far as an intake manifold design is concerned...an air intake, CAI or short ram intake, works differently and can't really be compared. The flow and pressure of the air is less for long tube CAI's at the lower RPMS..thus a drop in performance.
Rick
Old Oct 7, 2006 | 07:37 PM
Cracker Red's Avatar
I'll try and dyno a long CAI I made vs the factory intake. EVERY SINGLE TIME I've ever put a longer intake on a car, it's gained a decent shot of torque down low, but there is always the exception.
Kelvin Style006
May 23, 2016 03:47 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
Racova
2nd Gen (V36) Sedan
Aug 8, 2015 10:21 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
G35Sask
Engine - Intake/Fuel
Aug 1, 2015 11:16 AM
