Fast Intentions 300 Cell Metallic High Flow Cats *Pictures*
#47
Originally Posted by Dan_K
So I will be ok with ceramics and the Vortech? I might lose a couple hp vs. the metallics?
It's a matter of what could happen over time, and trying to extend that replacement time as much as possible.
Rick
#48
Originally Posted by ISMSOLUTIONS
OK - so I have them, and am happy with them, and have no problems with them. You have to understand as well, that warranties do not include modified cars, because of them being either rich or lean. With this said - if I was not as affilitated as I am with FI - I would go with Metallics while being Vorteched.
Rick
Rick
#49
So you are saying that the warranty on the cats only applies if your car is stock? Most people who buys these HFC's will have modified cars whether it be an intake or turbo. Where does the warranty stop and begin? I understand that the life of the cat will decrease compared from a FI'd car to a car with only an intake, but the warranty should take this into account.
FI will warranty all the welds and workmanship, as always. But if a cracked brick, or a burned out unit is sent in - what can you expect FI to do? The brick failed out of normal conditions. This information is disclosed as well.
If the brick breaks for fails, as it is determined that none of these conditions exists - then of course it will be warranted.
Hope that helps clear it up...
Rick
#50
on
If you are Supercharged, Turbocharged, or are using Nitrous you will void your warranty on our cats.
Reason being we cannot monitor who tunes those vehicles and your A/F numbers might be all over the map. If they are you will eventually destory the brick inside of the cat.(Nitrous especially. You will cook the brick in the cat.)
#51
#52
Originally Posted by _jb
Anybody got FI HFC's with HKS exhaust? Sound good? How loud?
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
loud enough that people can tell the difference. i have a friend with a 350z & hks exhaust and mine is noticeable louder.
also, when i roll to meets...people have asked me what i did to my hks to give it that extra growl.
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
#53
on
yo hero,
any tips on how to break loose those two bolts on facing the front of the car? I tried the 26" extension method but I couldn't get at the bolts at a straight on angle.
I went through the hood to break loose the nuts but it's near impossible to get it perfectly flush into the socket wrench with all those damn hoses in the way. Any tips? Those two nuts are ****** driving me nuts...
#54
Originally Posted by SuperShick
yo hero,
#56
StreetStandard
Exhaust-Vendor
11
01-12-2016 03:21 PM
