Cold air Induction for 07 G35 Sedan
Old Dec 18, 2006 | 12:22 PM
Doran's Avatar
Does anyone one know where i can Get cold Air for my 07 G35 Sedan????
Old Dec 18, 2006 | 01:04 PM
ballisticus's Avatar
You already have one from the factory.
Old Dec 18, 2006 | 09:28 PM
Hydrazine's Avatar
Its hard to imagine that any substantial improvement can be made on the stock design.
But you never know.
Old Dec 19, 2006 | 07:39 AM
cato's Avatar
SouthernComfort Moderator
Canada?
Old Dec 19, 2006 | 08:30 AM
But you never know.
Agreed. But I'm more interested whether the '07 induction setup could bolt up to the earlier sedans. I'm on the lookout for wrecked '07's just in case. Would have to somehow parallel wire the 2 throttlebodies off of one signal. Hopefully that won't overload the source in the ECU.
Old Dec 19, 2006 | 12:46 PM
ISMSOLUTIONS's Avatar
Check with JWT - they have had a sedan for a few months now and have been designing stuff already...
Rick
Old Dec 19, 2006 | 04:11 PM
Hydrazine's Avatar
In that case, no. Its not possible to transfer the 07 plenum assembly to a prior year VQ. They are indeed completly different.
The runner ID is rectangular and could never mate up to our oval port manifold.
Round hole square peg scenario... Maybe a hammer could fix this?
Old Dec 19, 2006 | 05:44 PM
Unless one was to replace the whole injector assembly all the way to the heads. If the heads are different on the HR, then no go of course.
Old Dec 19, 2006 | 05:53 PM
Jeff92se's Avatar
Red Card Crew
I don't think it would be as easy as that. There are now two mafs with two smaller (I'm guessing) tube sizes. Your single maf ecu is calibrated to read one maf signal with larger tube size. I imagine it would screw up the mass of air flow readings as it uses the maf tube size as part of it's calculations. I would think the TB reading would be the least of the problems. But you'd run into the same problems as the mafs. TBs are probably smaller in size. This xx% on your single larger TB wouldn't = the readings off two smaller TB open readings.
Old Dec 19, 2006 | 08:42 PM
You're right. It would be a mess. Best left up to the JWT guys if they are indeed developing a twin setup. BTW, whatever happened with this beast?
https://g35driver.com/forums/forced-induction/77913-sfr-twin-intake-plenum.html
champppy
Mar 31, 2020 12:25 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Blakelyg35
Aug 15, 2015 12:12 PM
laksjd84
Jul 24, 2015 05:12 PM
justgotg35
Jul 19, 2015 12:33 PM
