Intake Opinions!!
Old Jan 16, 2007 | 02:27 PM
redriderr's Avatar
i have a amsoil drop in on order...
Old Jan 16, 2007 | 03:12 PM
DRA-G35-ON's Avatar
Originally Posted by Nismo G
Not really, the CAI has a longer tube so the sound will echo a little bit more in the tube adding a louder sound. None of the CAI do anything for the car UNLESS you get a tune. Then there is a big difference. The reason why the CAI or regular short ram dont add any more power is because the ECU that nissan designed for the car is so restrictive. It will not allow more air into the engine past stock. So the even if you have something to allow more air in it wont let it. Now once you over ride the stock ECU setting then you will see different gains for different air intakes. A CAI will provide the most power of all of them once you tune the ECU.
-sean
When you say override the ecu, do you mean just resetting it?
Old Jan 20, 2007 | 02:53 AM
j-velocity's Avatar
Just installed K&N drop in filter on my 6MT w/ z-tube...
I think there is a difference in terms of performance....
The car pulls a little harder and rev smoother.....
Old Jan 21, 2007 | 12:47 AM
srmfball's Avatar
I just ordered a Z-tube with pop charger
Old Jan 21, 2007 | 01:11 AM
robzg35's Avatar
Question
yeah, how do you override the ecu? Has anyone done this and seen differences?
Old Feb 28, 2007 | 05:52 PM
rcdash's Avatar
not reset, re-tune.
as in change air/fuel ratio via reflash or ECU piggy back like unichip or utec.
Old Feb 28, 2007 | 06:25 PM
truplay8's Avatar
THE BATMOBILE
its all sounds, so i mean which ever one appeals to you.......i like the whistle of injen.......none fo these intakes provide any power, jst better air flow and some noise
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
vamarris
Sep 26, 2015 12:56 PM
