Stillen HI-Flow Prob/Quest
Old Nov 19, 2003 | 08:43 PM
jayhawkSATX's Avatar
I own a 2003.5 G35 coupe 6MT with approx 5000 miles on it. Recently (at approx 3700 miles) I installed a Stillen Hi-Flow airbox on the Coupe and love it. The intake sound is amazing. I have not converted to the Z-Tube as of yet because I like the way the current Engine cover fits. However I have encountered a problem!
My car does stall when shifting into neutral at speed as I have prev read about. Usually highway speed and is not much of a problem (since rarely do I depress the clutch) but it has happened coasting up to stoplights at approx 15 miles per hour. (Total times 6-8) I am aware many others have experienced this problem and was curious if adding the Z-tube would not only awaken the beast (so to speak) but does it fix this problem?? Is it the baffle in the G35C intake that causes the problem?? Any additional information would be helpful. Thanks and keep up the interesting posts!
Old Nov 20, 2003 | 01:31 AM
SoCalTed's Avatar
Re: Stillen HI-Flow Prob/Quest
did you do all the resets? (not just the ECU, but all of them)
http://www.technosquareinc.com/350reset.htm
have had mine for 1k miles with zero issues.
'03 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
Old Nov 20, 2003 | 11:50 PM
ericinmia's Avatar
I have no issues too, from a tech I talked to it was the air flow sensor that would cause this problem.... so check your install.
Peace
-Eric
'03.5 Silver/Black | Prem | Perf | Aero | Stillen Hi-Flow | Z -Tube | Nismo Oil/Radiator Caps | Solid Allum Pedals | Allum Matts (Infinit Logo) | 15% Tints | Valentine1 | Hide-Away License Plate!
Old Nov 21, 2003 | 04:02 PM
C_Lawd's Avatar
Is a reset required after Z-Tube installation?
Old Nov 21, 2003 | 04:18 PM
G35Gnome's Avatar
"I have not converted to the Z-Tube as of yet because I like the way the current Engine cover fits." Your engine cover will fit fine, like normal with the Z tube.
Crawford Plenum / Z tube + Stillen Hi-Flow / Borla Dual Exhaust / Stillen Xdrilled+Stotted Rotors
Best 1/4 mile 14.371 @ 100.29, 60ft 2.347
Old Nov 21, 2003 | 05:12 PM
Tfasano's Avatar
Not necessarily, he will have a chunk of it missing from the resonator he takes off with the original tube. It definitely looks awkward.
Luv My G
Old Nov 21, 2003 | 05:16 PM
G35Gnome's Avatar
hmm you might be right, I actually never put the cover back on since the very first time I took it off so I truelly dont know. I was just saying from the looks of it.
Old Nov 21, 2003 | 05:17 PM
C_Lawd's Avatar
But does the cover still fit normally?
Old Nov 21, 2003 | 10:04 PM
Gordgee's Avatar
Administrator
The cover still fits normally, it just looks like a chunk was taken out of it. It'd be the same if you went with a CAI as well.
<font color=green>GG</font color=green>
Old Nov 22, 2003 | 01:20 PM
Thanks for your responses. I have not performed the complex ECU reset. Just left the battery off overnight. Do you think resetting the mass air flow would help?? Why would the "zero" position change just with changing the airbox? I guess I just dont understand.
As for the appearance of the engine. I would be willing to change if the Z-tube fixed the stalling probs or gave a little more growel under the hood. Any Suggestions? And thanks for all of your posts.
Old Nov 22, 2003 | 01:51 PM
Gordgee's Avatar
Administrator
The z-Duct gives a bit more of a "throaty growl" under the hood above 3500 RPM.
Old Nov 23, 2003 | 11:04 AM
I must admit I am tempted to buy the Z tube now. If I add the Z-tube do I use the clamps from the current intake or buy the clamps from the 350 Z air duct?? How long did it take to install??
Thanks again for all the info!!!
Old Nov 23, 2003 | 11:16 AM
Msedanman's Avatar
O.F. Administrator
I used regular hose clamps on mine replacing the wire clamp. Install took about 10 minutes.
The mod will net a few hp and torques.
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
hawaiian5
Sep 20, 2015 07:12 PM
