Can Headers Cause CELs?
Old Feb 20, 2007 | 06:33 PM
qmaster8's Avatar
I am still trying to find the root of my CELs codes P1273 and P1283.
Could they be related to Strup headers being installed? I forgot if I had them before I installed the headers, but I am about ready to put the factory manifolds back on the car.
Someone told me that these CELs are related to the upstream O2 sensor which actually affects drivability (I get 15 mpg lately). It is located where the header meets the engine, so this is why I think it might be causing trouble.
I just want to make sure before I swap the manifold back.
Thanks.
Jason
Old Feb 20, 2007 | 06:40 PM
MrBillMartin's Avatar
hmm, i havent heard headers throwing lights, but im sure its possible. and im pretty sure your right, your car is running in some sort of limp mode. i would think about trying spacers(sparkplug non-foulers) on the top o2 sensors. cheapest and easiest way to trick the ecu.
what do those codes say tho??
dont rush to put nething stock back on.
Old Feb 20, 2007 | 06:44 PM
Hi-TechG35's Avatar
Yes they can especially because it has to do with o2 sensors and stuff. Have you tried reseting your ECU?
Old Feb 21, 2007 | 09:49 AM
qmaster8's Avatar
Yup
I have resetted it multiple times, including the battery method, pedal, and with an ODBII scanner.
No go.
Any other ideas?
Thanks.
Jason
Old Feb 21, 2007 | 10:56 AM
ballisticus's Avatar
Absolutely DO NOT put non-foulers on the upper O2 sensors (closest to the engine)! That is the primary closed-loop that adjusts your mix. Doing that will royally screw things up. The ONLY sensors to add non-foulers to are the ones threaded into the cats or testpipes. Those are only alarm sensors and dont actually control fuel delivery.
If you are throwing a light and you still have cats, then your mix is off due to a vacuum leak at the intake, or you are sucking air into the exhaust from a bad header install/gasket etc. If you had someone install them, take it back and have them check the bolts etc. If you did it, then you will have to diagnose yourself. But if you are getting lousy mileage, then you are rich, which means the fuel management thinks you have too much oxygen in the exhaust and is adding fuel. Makes me think you have an exhaust leak somewhere.
Old Feb 22, 2007 | 03:06 PM
GT-Ron's Avatar
Been running MREV, Headers and Cats for a good while now without ever throwing a CEL. Maybe they fouled an O2 sensor during the install?
Old Feb 22, 2007 | 04:01 PM
Augy's Avatar
I got my CEL when I put in my helix test pipes
Old Feb 22, 2007 | 04:32 PM
g35rcr's Avatar
test pipe o2 sensors need defoulers, the headers dont...my test pipes on my 03 didnt need defoulers on my test pipes...never went off
Old Jun 11, 2009 | 09:30 PM
4drmadness's Avatar
Hey guys im getting those two codes as well P1273 and P1283. Did anyone figure out how to fix the problem? i have dc headers and kinetix hfc and dont want to put back stock cats.
Old Sep 29, 2009 | 10:28 PM
G35CDriver's Avatar
I am now throwing a CEL in every 3 days after reset. I think a sensor on one of the test pipes may be bad do to the fact the i dripped anti-seize in it while dressing the threads. I'm going to bet on that one. ---Idiot---
06g35
Feb 14, 2022 05:59 AM
magnetism80
Jan 27, 2016 12:57 PM
alessandro
Oct 8, 2015 09:29 AM
lavtxa
Sep 21, 2015 11:51 AM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
