Injen Intake RD1990
Old Jan 14, 2004 | 06:14 AM
skeleton_cru's Avatar
Sedan
Injen Intake RD1990
I have ordered this cold air intake for my sedan. Anyone have experience installing it? Ease of installation? Performance impressions? Any input would be appreciated. Thanks.
...Skeleton Cru
Old Jan 14, 2004 | 09:41 AM
SilverG35C's Avatar
Re: Injen Intake RD1990
Don't have it on the Sedan, but you can check out a comprehensive install and review on the Coupe system at www.g35coupe.net
Jason Siu
G35STUFF!
Old Jan 14, 2004 | 11:16 AM
Gsedan35's Avatar
I have the RD1990. When you get it, do not worry about the install instructions telling you to remove the whole front bumper skin. All you need to do is to jack up the left front tire. Remove that tire and simply remove the front half of the plastic inner fender liner, estreamly easy and your access is right their. I do not recommend that you remove the whole foam block or the plastic panel near it like the directions say to. Here's what I did.
The red arrow point to where I used a X-acto knife to slice a section of the foam block off. Make sure you reset you ECU when your done and allow for a period of time to let the ECU learn. While it's learning you may experience a stumble here and their as several non oem designs have done. As far as gains to be felt, I noticed a slight increase in power. I've seen some reviewer's that would say they got more however.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Jan 19, 2004 | 01:35 AM
Sedan
Thanks a lot for the info, it will come in very handy when I do the install.
...Skeleton Cru
Old Jan 19, 2004 | 01:38 AM
Sedan
Questions:
Why not remove all the foam block and the plastic panel?
What period of time before the car is running normal again?
Thanks again.
...Skeleton Cru
Old Jan 19, 2004 | 12:52 PM
miwung's Avatar
I got the same intake, I didn't remove the whole block of foam in fear that water would get in there. If you remove the foam block you see the air filter from the front of the car, that alone got me worried about the water.
in any case, I'm not sure which one is right, I've heard both sides of the argument. I chose to leave mine in for now, maybe I'll move it. Logically thinking about it, would tell you to remove it so more air can get into the air filter......
as far as the ECU learn time, I think a few sessions of driving should be sufficient. The ECU will learn how you drive anyways, whether you grandma it, or ride hard from what i understand
good luck
-miwung
04 coupe | silver/black
**I told the salesman, I want everything the G comes with **
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
vamarris
Sep 26, 2015 12:56 PM
