Stillen dual exhaust install...
Old Jul 2, 2007 | 03:03 PM
joe603's Avatar
Question Stillen dual exhaust install...
Hey guys, I'm looking to get the Stillen dual-path exhaust for my 05 coupe. Is this something I can do in the garage, or should I get a shop to do it? I have ramps, but it will be tight under the car...has anyone done it at home (no-lift)? Thanks!!
Old Jul 2, 2007 | 06:27 PM
Beebo's Avatar
it can be done at home
Old Jul 2, 2007 | 06:29 PM
MixturePinoy's Avatar
Just remember you gotta break those bolts loose, you might want to have some good air tools or be able to put some elbow grease into it. and make sure to get help, it's easier to bolt on the exhaust with 4 hands. good luck
Old Jul 3, 2007 | 11:03 AM
joe603's Avatar
ahhh....Penetrating oil must be added to my list! Are the Jack points easy to spot? Any recommendations for getting the car up...this is my first garage install; I used to have access to a lift
Old Aug 7, 2007 | 11:01 AM
joe603's Avatar
Any wielding involved or is it all bolt-on? The exhaust should be here this week...
Old Aug 7, 2007 | 11:09 AM
izmir41500's Avatar
G35driver Addict
all bolt on. easy if you can break the stock bolts loose. just get the car high enough on the jackstands or ramp. make sure you torque to the right specs also and check for leaks.
Old Aug 7, 2007 | 11:16 AM
ballisticus's Avatar
Most muffler shops will install it for $60 (45 minutes to an hour of labor). Not really worth crawling under there and risking injury etc for a lousy $60. Plus if anything goes wrong later, they have insurance to cover any damage. You install it, you are liable.
Old Aug 7, 2007 | 12:35 PM
joe603's Avatar
...it is hot as hell out...maybe I will take it to my shop
Old Aug 7, 2007 | 02:23 PM
Skaterbasist's Avatar
Retired SuperMod
Do it yourself. It's fun, easy, and you will have that satisfaction of accomplishment (and a few extra bucks you'd save).
It's all bolt-on
Old Aug 7, 2007 | 04:56 PM
spooze's Avatar
nice choice. im also looking into the stillen
Old Aug 14, 2007 | 12:24 PM
joe603's Avatar
Use band clamps, not the U-clamps that are with the Stillen kit...mine had a leak on the drivers' side and because they used the U-clamps first, band clamps would also leak due to the indent made.
I'm getting the mid-pipes wielded today...
Old Aug 25, 2007 | 02:41 AM
spooze's Avatar
hows your exhaust
g.spot
May 9, 2016 10:54 PM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
