Test pipes cracked my y-pipe,
Old Jul 12, 2007 | 08:00 PM
Jony's Avatar
Review, StrupTest pipes....
I thought i would share my experience with everyone and hope you guys choose your test pipes wisely. I installed my strup test pipes last week with only 800km on my 07, i started to hear a rattle coming from under my car at certain rpms, the best way to describe it would be the sound of a rattle snake. After going to dealership and a reputable mechanic, they both told me that the cause is most likely the test pipes. When the test pipes are bolted on to the y pipe, the design of the strup tps apparently stretches the y pipe outwards and causing the inside to break down.
Besides the design, i have also noticed that the two 02 holes are the not aligned properly, one of the 02 sensor was slanted downward making it very vulnerable when you go over bumps.
I replaced my tps today with fast intentions resonated tps, and what a difference in quality and sound. It complement the stock exhaust perfectly, i will post a video when i get a chance.
Old Jul 13, 2007 | 03:12 AM
Beebo's Avatar
Fi Ftw!!!
Old Jul 13, 2007 | 01:22 PM
GeeCoupe's Avatar
Hey were the Strup resonated? I have to buy another pair of test pipes so I need to make a choice..
The same thing happened to me, I had some resonated test pipes which gave me no problems for a long time but when I installed an aftermarket y-pipe they didn't work well together and the welds cracks on both a coupe of times.
Question: Do you think an H-pipe will be less stress and less prone to craking?
Old Jul 13, 2007 | 04:05 PM
Jony's Avatar
i had the test pipes, i don't think strup make resonated test pipes. If the stock y pipes worked for you, maybe you should just stick with your stock. I am not sure about the h-pipe.
Old Jul 13, 2007 | 04:14 PM
da mayor's Avatar
i never had any issues w/ the stock Y pipe and test pipes-- i know whoever installs it and they bend the y-pipe the wrong way it will crack it beforehand
Old Jul 24, 2008 | 04:12 AM
kpopseven's Avatar
what .... yall guys are worring me now...
i was thinking of getting the strup test pipe
but i saw the TOMEI one's ...
they just bolted it on with eaz but my o2 sencer was a hassle to get off..
i wonder if my y pipe is going to break ? what should i check for in detail?
Old Jul 24, 2008 | 06:25 AM
jimmykce1's Avatar
This may be a stupid question, If you have test pipes on your car instead of stock cats or HFC's would you fail state inspection?? I know some states use sniffers to test emmissions.
Old Jul 25, 2008 | 12:04 AM
kpopseven's Avatar
yes you would fail state inspection unless you de bug it ....
i just got the bypassers or some thing and reflash my ecu and no check light
if your check light dont come one .. it will pass
Old Jul 26, 2008 | 04:02 AM
MadMonkey's Avatar
So either you replaced your Y-pipe or the dealer was lying. I would assume they were lying, but let me know.
magnetism80
Feb 1, 2019 10:00 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
kevintandmd
Sep 3, 2015 06:41 PM
erich2780
Sep 3, 2015 03:23 PM
