Injen CAI Problem
Old Sep 16, 2007 | 01:40 PM
kokor1's Avatar
Angry Injen CAI Problem
Need Help!!!!! I just installed a Injen CAI in my 04 coupe. It seems to be ok at idle and low rpm and speed. But when I floor it from a dead stop, it shuts off right when it reaches about 5 grand in the r's. WTF is going on?Has anyone experienced this? Please help!!!!
Thanks,
Koko
Old Sep 16, 2007 | 01:47 PM
Adon's Avatar
oh man.. this is exactly why I'm still doubtful on going with a CAI... I was looking at the AEM, Injen and Fujita... and for the most part they should work as normal... but at the same time there's problems with Hydrolocking, and also problems just like you described... just random engine malfunctions!
did you clean out the MAF sensor before installing it back into the Injen ??
Old Sep 16, 2007 | 01:54 PM
Calvin's Avatar
Overglorified Altima
Old Sep 16, 2007 | 01:56 PM
O HELLA JDM's Avatar
i had the injen cai...try to check the air sensor....if not install your stock intake and see what happens if it cuts out around 5k again..
Old Sep 16, 2007 | 04:30 PM
Still2Slow's Avatar
Get a pop charger, I've had CAIs and will NEVER own another one. Everytime the streets flooded, I would have to be real careful.
Old Sep 16, 2007 | 07:33 PM
Beebo's Avatar
it happens with INJEN its taking in to much air
Old Sep 16, 2007 | 07:44 PM
norcal_chan96's Avatar
Are u letting off the gas when u get to high RPM's??? I know when i had my injen intake on, at high speeds letting off the gas would cause the air to get sucked out of the tube and cause a venturi effect... The air passing through the intake was greater than the air being sucked up from the motor; which sucks the air out of the tube...
Old Sep 16, 2007 | 10:25 PM
kokor1's Avatar
Thanks to all for your responses, 1. I will put the stock back on and see what happens. 2. I didn't take my foot off the gas, it just shuts down. 3. What I don't understand is that a friend of mine bought the same exact one and his car seems to work fine. 4. It works fine as long as i don't floor it above 5 grand. Any other suggestions?
Thanks,
Koko
Old Sep 16, 2007 | 11:57 PM
Beebo's Avatar
Thanks,
Koko
well what type of car does your friend have?
i say get a new short ram intake like Stillen
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
wuzz-upp
Oct 3, 2015 04:21 PM
mattdg35
Sep 14, 2015 11:28 AM
dorkstar
Engine - Exhaust
Sep 9, 2015 07:43 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
