350Z Intake Duct
350Z Intake Duct
With reference to the DIY thread, can someone explain what are the benefits of installing a 350Z intake duct as opposed to simply leaving the stock G35 unit. In the end, is it worth it?
G35 Coupe 6MT Brilliant Silver
Tinted Windows
7 -Wire Hyper Ground System
Hyper Voltage System
Aluminum Pedals
Complete Front-end Clear Bra
Tinted Windows
Aluminum Pedals
Re: 350Z Intake Duct
The Z duct has a smoother air flow path. You tend to get better HP numbers. I don't have so I can't say fro sure but many here couldn't live with it and a high flow intake like the Stillen box or the JWT POP Charger.
03.5 Sedan/B.Sil/Prem/Wntr/Aero/Tint/Rims/Hotchkis Sways--WHRER ARE OUR PARTS!
69 Chevelle Hard Top BB/4.11's/Posi
The 350Z intake tube is smoother and straighter than our stock tube, and doesn't have the quietening sound chamber on it that can rob h/p.
It's generally thought of as a good mod, and from what I understand will yield a few ponies for about $75 USD.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Yes, it is worth the $75. The growl is back with the 350Z
tube. Sounds better, more HP, etc....
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Underbody rear diffusers, Drilled aluminum pedals
If you ever flipped the air cleaner cover over on an old V-8, and the results made you smile, you will love this simple mod regardless of whether you find a few more ponies or not!
2004 | 6MTs | Diamond Graphite/Graphite
Upstate NY
Upstate NY
You'll love the sound. It's easy to do. Feeds air more efficiently to your plenum, since it is a straight shot in...that's where the 1 to 2 HP comes in.
This is what it's all about:
It's the best $75 you'll spend, other than on a tank full of premium.
-T
'03 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
-T
I know you can do it!! It takes less than 15 minutes.
If you aren't that comfortable with taking a socket to your engine compartment, then there is probably someone on the board that would be happy to assist.
If you are in SoCal, PM me and you can drop by some afternoon and I will put it on for ya.
Cheers,
-Ted
Cheers,
-Ted
you can do it. takes very little time at all. just follow the diy and you will be set. very easy install.
Daniel
5AT Coupe / DP / Willow / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights / Z - Tube / OEM Remote Window UP in 1 day<P ID="edit"><FONT class="small"><EM>Edited by SFLG35 on 03/24/04 08:15 AM.</EM></FONT></P>
Daniel
It is very easy. I didn't even read the diy. It's even better with the Hi-Flow.
2K4 G35x/Brilliant Silver/Graphite/Premium/Wood
Stillen Hi-Flow/ Z tube/ Ground Kit
16576-CD000
G35C - 6MT, DG/G, Aero, BSM, Flaps, Stillen Intake, Z tube, Crawford v5, 6 Wire Grounding Kit, Clear Corners, 2nd Battery (Brake) Cover, Sirius, Momo F16 Evo Shifter, 30% 3M Tint & more to go
Sheesh! Even my 13 year old could do this mod. It's sooooo
easy. Give yourself some credit.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
