Intake Comparision with dyno charts
Originally Posted by usmcmark
my .02...
-on heatsoak: it's ur upper plunum that''s gonna cause the most heatsoak
-CAI vs SR: technically, any intake that draws air from infront of the radiator is a true CAI. the stock set up is pretty much a SR because of the power duct. CAI pipping heats up worse because there's more of it. SR that still uses the factory duct is still cold air as long as there's a heatshield near the filter. no aftermarket intake makes more than a few hp w/o a tune but alot of them DO loose power.
-Best intake for strait up performance: OEM 350Z-tube & hf panel filter
-Best out of the box intake system: Z-tube & Stillen hf box
-Best intake all around(sound, looks & performance): poished intake pipe(ARC or any polished type Z-tube) & JWT pop-charger
-My setup: ARC + JWT + Blitz
My performance mods:
-JWT Popcharger w/Blitz SUS filter
-ARC intake pipe
-Motordyne 5/16" Iso-Thermal plenum spacer
-AMS light wieght pulleys
-HKS Twin Power DLI-II ignition amp
-Stillen grounding kit(silver)
-NGK Laser Platinum spark plugs(one step colder)
-Stillen engine damper
-DC Sports ceramic coated headers
-Kinetix High-Flow Cats
-Stillen Generation 2 dual-path cat-back exhaust
-Technosquare ECU reflash & tune
-ARC intake pipe
Wanna sell me that intake where did you buy all the parts for it? looks really cleannn
Originally Posted by iwant2drift
ur engine bay and setup is GORGEOUS!!!
Originally Posted by Jeff92se
usmcmark. Anyway I can get you to use a diff filter? Those SS blitz units filter terrible. I mean really bad. The new Amsoil cone eu filters look like winners. Flow and filtration
Red Card Crew
Originally Posted by OCG35
Jeff did you ever find the Ams part number that replaced the K&N cone filter that comes with Stillen?... I've been wanting use a dry cone filter for a couple years but have yet to find an actually correct/perfect fit.
