Ram Air Popcharger...?
Old May 2, 2004 | 03:22 PM
MyGUnit's Avatar
I'm trying to figure out a way to make this a "ram air system" cause i think it has more potential if i were to find a way to make it...the way the car is now with the popcharger, it doens't get as much air as it should be...has anyone done this kind of mod?
Mitch
2004 G35C AT
Blk/Blk
Prem.Aero.Perf.Nav
Nav/TV Tuner w/ PS 2
2-10" Subs w/ Rockford Amp
Clear Corners
Pop Charger
Z-Tube
Old May 3, 2004 | 01:28 AM
klg35's Avatar
Re: Ram Air Popcharger...?
not sure if this is what you're looking for: i just took off that power duct piece on the oem airbox.....i guess you can custom fab something for the popcharger........
04 6mt Sedan / stock airbox mod / z-tube / k&n panel filter / crank pulley / 18" r/h c2s / s-tein springs<P ID="edit"><FONT class="small"><EM>Edited by klg35 on 05/02/04 10:30 PM.</EM></FONT></P>
Old May 3, 2004 | 02:32 PM
fluffydot's Avatar
I know what you mean. I think what we need is a tube/tunnel that goes from the lower valence up into where the popcharger is.
Grupp-M intake has a tube that does what we want. but I think their stuff is real pricey. a tube like that can't be very hard to make. probably can use fibreglass or something. might require some cutting of the bumper lining or somthing...
Old May 3, 2004 | 05:11 PM
cato's Avatar
SouthernComfort Moderator
Well...The Pop Charger sits where the stock air box does,
as well as the Stillen HFAB. I would guess that there is quite
a bit of "ram air" coming in thru the grille and the horizontal
air scoop. Maybe the "gutter intake" is what you are thinking
about?
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals
Old May 3, 2004 | 06:28 PM
Anonymous's Avatar
Here's the solution you were looking for: https://g35driver.com/forums/showfla...sed&sb=5&part=
Anonymous's Avatar
Old May 3, 2004 | 07:03 PM
esemes's Avatar
"ram air" really needs an airbox that is pressurized........
for this, we need better (more effective seals and an airtight box/intake tract design)..
Old May 4, 2004 | 07:32 AM
cato's Avatar
You mean like the stock air box?
Old May 4, 2004 | 07:48 AM
esemes's Avatar
CATO-
"yes".... to an extent, the oem box utilizes the rammed air principle, BUT the poor intake tract/seal make it less than ideal....
KruZZe
Feb 27, 2023 05:04 PM
KallDay86
Jan 8, 2016 12:42 AM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
