Rev-Up airbox on a VQ35DE - special note
Old Jan 2, 2009 | 04:44 PM
  #46
Turbolence32's Avatar
Originally Posted by LightsOut
keep the spacer, put a ztube or stock G tube and add the rev-up box
But if I don't have a spacer yet, do I need to get it to add the revup box, or is that only if I'm going to use a ztube as well?
Trying to flush out a list of parts I need before I start buying..
Thanks for your help!
Old Jan 2, 2009 | 05:00 PM
  #47
Seymore's Avatar
Spacer, z-tube, rev-up airbox, K&N filter, etc. can all be done separately or all at once, it just depends on your budget and preferred approach.
  #48
LightsOut's Avatar
SIETESG
buy the spacer first then choose the air box or zutube, or buy the air box and ztube at the same time.
box and ztube should be around 200 or less.
Old Jan 3, 2009 | 01:55 AM
  #49
JSpec350GT's Avatar
I got 06 air intake box with velocity stack for sale here...if someone's looking for one.
Old Jan 3, 2009 | 02:19 AM
  #50
Tunerz_Store's Avatar
Got my 06 350z airbox in the other day. Today I switched out the velocity stack and I must say there is definitely a difference in exhaust note and some low end grunt. I would say it was worth the $30.00. HR Y pipe is up next.
Old Jan 3, 2009 | 11:17 AM
  #51
jimmyfogg's Avatar
Can anyone recommend a place other than everythingg35.com (which I couldn't find the part 16526-AC700 on) or infinitipartsusa.com, preferably in Canada so that I don't have to pay the $146 from the dealer for the air box...
Old Jan 3, 2009 | 12:50 PM
  #52
LightsOut's Avatar
SIETESG
^^^^^the dealer is only 89.00 - riverside infiniti
jump on our sister forum i saw a couple of 06 z selling their airboxes
Old Jan 3, 2009 | 04:46 PM
  #53
xx7sephiroth7xx's Avatar
G
Not 100% positive, but I'm pretty sure that the Z airboxes are shaped differently than the ones on the G.
Old Jan 4, 2009 | 01:08 AM
  #54
DaveB's Avatar
+1. They are. You can get a Z RevUp airbox, but you'll have to drill out the rivets on the velocity stack and then swap velocity stacks between the two airboxes. Those are the only shared parts.
Old Jan 4, 2009 | 10:50 AM
  #55
jimmyfogg's Avatar
I know that this might not be the correct spot for this question, but can someone briefly explain what a 5/16" spacer does? I'm not very technically inclined, but I did manage to install my K&N drop-in without any trouble...
Old Jan 7, 2009 | 08:32 AM
  #56
jimmykce1's Avatar
The spacer allows more air flow to get to the front cylinders because on the stock plenium slopes down and starves the front cylinders for air. This is the best performance upgrade for our cars. You will feel the different too once its installed. I believe it will give you 10 more HP at the wheels.
Old Jan 8, 2009 | 06:52 PM
  #57
jimmykce1's Avatar
I got my rev-up air box today and will be putting it on tomorrow. I noticed that there is a small hallow tube sticking out. Do I need to take the rubber piece off my old one and put it on the new one. Let me know if I need to do this.
Old Jan 8, 2009 | 07:03 PM
  #58
CBRworm's Avatar
20 Year Member
Does anyone sense any irony that we take parts off the non-revup to make the revup faster and parts off the revup to make the non-revup faster
Old Jan 8, 2009 | 07:22 PM
  #59
OCG35's Avatar
are you guys ordering the entire air box? Or just the portion that has the velocity stack? (if it’s even sold separately)
Old Jan 8, 2009 | 07:40 PM
  #60
jimmykce1's Avatar
Just the back half of the box
