Idle is dropping like crazy, car feels like its almost gona give up.
Old Feb 8, 2009 | 08:58 PM
4drmadness's Avatar
Hey guys i just put a new md, and design chaos spacer. my idle has been acting super weird. it feels like my car is almost gona shut off. what procdures do i need to do to get back my idle to spec? Im getting a tune as well. should i just tell my tuner to bump up my idle? will that help. Do you think i have a leak?
Old Feb 8, 2009 | 09:08 PM
5150DS's Avatar
Sounds like a vacuum leak. What kind of gasket did you use to install the spacer?
Edit:
In your original post, did you say you put two spacers in????
Old Feb 8, 2009 | 09:13 PM
4drmadness's Avatar
yea design chaos throttle body spacer, and md 5/16 spacer. i kept the stock gasket for my md spacer. When i removed the throttle body, i didnot find a gasket for that. im thinking that might be the problem
Old Feb 8, 2009 | 09:14 PM
5150DS's Avatar
Is the md spacer new or used?
Old Feb 8, 2009 | 09:15 PM
4drmadness's Avatar
its new
Old Feb 8, 2009 | 09:16 PM
5150DS's Avatar
So there are gaskets between both the top and bottom of the md spacer? Stock on one side and the md on the other.
One thing you might look at is if you tightened the spacer with the rubber thing around the oil fill spout. That has been known to get caught when installing a spacer.
Old Feb 8, 2009 | 09:21 PM
4drmadness's Avatar
i put the stock gasket underneath the md spacer. There is no gasket on top of it. btw is there a way to see where the leak is coming from?
Old Feb 9, 2009 | 02:15 AM
Jeff92se's Avatar
Red Card Crew
You unplug your TB connector when you put that spacer in? yes = idle relearn procedure needed.
If you have a leak in the plenum spacer, you'd know it the instant the car was started. ie.. a loud shreek noise.
Old Feb 9, 2009 | 02:27 AM
4drmadness's Avatar
yea i performed the idle realearn procedure a couple of times, and it still has weird idle. im jus gona try doin it a couple more times
Old Feb 9, 2009 | 02:34 AM
rookie's Avatar
Need a gasket on the throttle body. Did that spacer have an o-ring on one side of it?
Old Feb 9, 2009 | 02:39 AM
4drmadness's Avatar
yea the spacer had the two O rings on each side. Do you know what the stock gasket lloks like, cause i didnt see one. i think that might be a problem
Old Feb 9, 2009 | 02:50 AM
butkiss1's Avatar
I had the same prob Viv when i installed my 1/2" spacer Didnt torque down the long bolts in the center of the manifold enough, had a leak , torqued it , problem solved.By the way you ready for another one?
Old Feb 9, 2009 | 02:58 AM
rookie's Avatar
Looks like this. http://cgi.ebay.com/ebaymotors/FACTO...spagenameZWD1V
But yeah, you probably have a slight vacuum leak somewhere.
Old Feb 9, 2009 | 10:45 AM
PearlG35x's Avatar
Had the same issue... after installing spacer... i forgot to reconnect a vaccum hose.. check all your hoses.. even the one on the passanger side of the plenum... thats the one i forgot...
Old Feb 9, 2009 | 02:57 PM
4drmadness's Avatar
Yea i will defintely check out if i left any hoses as well. Im thinkin it is a leak, i just dont know where the leak is coming from
