o2 sensor covered on warrenty?
Old Mar 12, 2009 | 11:20 PM
jrozul00's Avatar
i just got a ses light on today just normal driving. i went to get it checked out and it came up p0133 o2 sensor circuit to slow or something like that. anyways is a 02 sensor covered on warrenty? car only gots 23k miles.
Old Mar 12, 2009 | 11:27 PM
Hi-TechG35's Avatar
You should be covered. 23k. definately.
Old Mar 12, 2009 | 11:37 PM
gary c's Avatar
S/B (SHOULD BE)
Gary
Old Mar 14, 2009 | 07:52 PM
BerkTechnology's Avatar
That's the sensor in the header. Yes should be covered under warranty but dealers can sometimes try to pull one on you.....
Old Mar 14, 2009 | 10:01 PM
sliderg35's Avatar
I had that code, changed the sensor and still had the code (intermittently). I finally got rid of it by cutting off the connector and soldering the O2 sensor in. No trouble since. It was a bad connector that was going nuts when it got wet. If they make you pay for the sensor, make sure they will give you your money back if the code returns!
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
wuzz-upp
Oct 3, 2015 04:21 PM
n2fooz
Sep 4, 2015 07:46 PM
UT G35
Sep 3, 2015 03:58 PM
