It's raining and I have CAI
Old Mar 26, 2003 | 03:10 PM
OvaYahead's Avatar
Re: It's raining and I have CAI
yes you can make it into a short ram. just fabricate a small piece.
It's not hard to put back in the stock config at all. about 20 minutes.
BS G35C 6spd navi/aero/prem
Old Mar 26, 2003 | 03:23 PM
paintballbitch's Avatar
IF I go CAI it takes long to remove the bumper =(
OvaYaHead, when you said just fabricate a small piece with the short ram setup...
It is just install the filter on the end of the first tube?
Old Mar 26, 2003 | 05:08 PM
OvaYahead's Avatar
yup, or you can try to make a small piece out of a large diameter pvc pipe. It's just that the mouth of the filter won't fit onto the mass air flow sensor tube. The air flow tube is a smaller diameter.
Old Mar 27, 2003 | 10:54 PM
RamboRami's Avatar
G35driver.com Moderator
Snow is no problem with CAI, snow doesnt go inside the hood, it just glides over the car when you drive...as if your car is in a wind-tunnel...CAI will always be better than stock in any temperature weather because there is much less air-restriction
<font color=green>-Ramb0</font color=green>
Old Mar 28, 2003 | 04:14 AM
BlackV35Skyline's Avatar
BlackV35Skyline: "Should i be concerned about having water enter my engine on the G35 Coupe. The cone filter is about 6-9 inches off the ground. Im really confused as i have been told not to worry. And i have also been told that i should buy the AEM Bypass Valve.
Also, if i do decide to put on a AEM Bypass Valve, do you think that the valve will take away some performance??
Response from Injen: " The most common way for water to enter the engine is for the filter to be entirely submerged. The length the water would then have to travel, significantly reduces the possibility of harm being done. You will need to drive through water levels up to the middle of your front bumper to get the filter under water. If you do encounter water levels that high, then I suggest you do not drive through it. With our cold air intake system, driving through rainstorms will not effect its performance.
Phillip
Customer Service Rep.
Injen Technology Co.,
www.injen.com
Old Mar 28, 2003 | 10:08 AM
I am not worry about hydrolocking the car anymore with the CAI
What I will do is get my friend to build me a mesh guard around the front & bottom of the CAI to keep the stone & bugs out of the filter
Still waiting for my 6000k HID bulbs so that I can do the installation at the same time.
jeffbdye
Jun 1, 2018 03:51 PM
Tmatheso
Dec 13, 2015 03:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
