Heat wrap the y-pipe?
Old Oct 23, 2009 | 07:44 PM
DieselX's Avatar
Hey, I'm planning on getting an aftermarket y-pipe and while I'm putting it on, might as well heat-wrap my HFCs. My question, is there a point to heatwrapping the y-pipe as well? Or am I wasting my time/money?
Old Oct 23, 2009 | 07:48 PM
kennymo's Avatar
to be honest you are wasting your money by heat wrapping any of it.
Old Oct 24, 2009 | 12:31 AM
DieselX's Avatar
I heard that it helps with rasp... biggest reason I got rid of test pipes
Old Oct 24, 2009 | 03:00 AM
kennymo's Avatar
most people that use heat wrap do not understand it. the only time it should be put on exhaust is on a motorcycle. so that you dont burn the **** out of your leg.
and if you are going to put it on your cars exhaust. i hope it has stainless steel piping. because if it doesnt. it will rust a lot quicker than it needs to. when the heat wrap gets wet from the rain. it will soak into the heat wrap and stay moist. witch will eventually rust the pipes out. yes people are going to say that thats stupid and its not going to happen. but yes it will. its not a quick process but its an unneccissary one. and if it really does get rid of the wrasp which i have never heard of then is itt really worth replacing the exhaust because it rusted through?
Old Oct 26, 2009 | 12:53 PM
Tollboothwilley's Avatar
it can weaken the welding points. especially when it gets wet. Now, the moisture doesnt stay in the material. It will dry out especially on the exhaust from a long drive.
Video Share
Jan 31, 2017 04:00 PM
DRG35R
Jan 31, 2016 07:14 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
hrdwirk1
Oct 2, 2015 06:34 PM
