n00b to modding - intake
Old Nov 1, 2009 | 11:52 PM
JoeSage's Avatar
So its my first real mod besides my drop in K & N filter but that really doesnt count. I just got a JWT pop charger, and it comes with the filter, the heat shield, the bracket that holds the filter in place, and the bolts which connect the filter to the MAF, and the bolt for the bracket. I read a DIY on it and it looks like im fine, but i just wanna make sure I its everything i need.
Also...to re-oil and clean the intake, can i use a K & N recharger kit? I dont know if that will oil it up and clean it or just clean it.
I appreciate the advice guys...
Old Nov 1, 2009 | 11:57 PM
AceG35X's Avatar
Sounds like you've got everything on the right track.. yes the K & N recharger kit will oil it up, just use a compressed air hose to clean out the dirt/grim/crap out of the filter, then use the kit to clean it.. let it sit overnight before you put it in again.
Old Nov 2, 2009 | 12:01 AM
JoeSage's Avatar
thank you so much. helps a crapload. so by compressed air hose you just mean an air compressor?
Old Nov 2, 2009 | 12:18 AM
AceG35X's Avatar
yeah lol
Old Nov 2, 2009 | 01:24 AM
4DGS's Avatar
DON'T USE COMPRESSED AIR
It destroys the fibers in the filter, it will never filter the same after using compressed air to blow the junk out.
What you need to do to clean it is get a bucket full of club soda and oxy clean or some kind of grease and gunk cleaner (if you use simple green water it down) I use club soda and oxy clean. Then you need to let it air dry, which is why most guys have two filters. So they don't have any downtime while cleaning it. Or just buy a crappy one to run for a day while it's drying.
Old Nov 2, 2009 | 02:32 AM
AceG35X's Avatar
^^^ ?? 4DGS, really?? wow.. if hes right than I am extremely sorry for giving that advice.. i haven't heard that before and most of my friends use compressed air.. but 4DGS' way is also very good.. just make sure its dry when u put it back!!!
Old Nov 2, 2009 | 04:09 AM
4DGS's Avatar
K&N recharge kit might actually say don't clean the filter with air right on the box, I know Green and Amsoils do.
Its not like instantly your engine explodes or anything but if you're using an aftermarket filter then why make it perform less than what it should.
Old Nov 2, 2009 | 06:42 AM
Blue Dream's Avatar
I drove ttrank's car solo
With some filters you can use the compressed air method, but not the oiled filters. I have the R2C intake and they recommend compressed air.
Very happy with it BTW.....
Old Nov 2, 2009 | 07:40 AM
snotf's Avatar
i'm fairly certain with a cotton oil-able filter the pressure from the air hose displaces the fibers and creates holes. even cleaning a different filter that isn't oilable, i wouldn't use air for the same reason. just scrub. i really don't think that it has anything to do with the oil itself, so much as the power of the air.
Old Nov 2, 2009 | 08:43 AM
blazeplacid's Avatar
4DGS is right, no compressed air with an Oiled filter
Also, The K&N oil is red, I dont know how that would react with the blue JWT filter
Old Nov 2, 2009 | 08:49 AM
tragedycat's Avatar
I used K&N oil last time I cleaned my PC, the red just makes the filter look dull.
Old Nov 2, 2009 | 01:26 PM
AceG35X's Avatar
So I have fujita.. that isnt oil based.. should i just dump it into club soda with soap and scrub? let dry.. and thats all?
Old Nov 2, 2009 | 02:12 PM
ttrank's Avatar
Grocery getter
I use the AEM dryflow filters, you soak and wash them out. I always did something like that with my old K&N's.
Old Nov 2, 2009 | 04:10 PM
Sacch's Avatar
The blue JWT filter will become purple!
Old Nov 2, 2009 | 04:24 PM
JoeSage's Avatar
thanks a lot guys. I dont care about the color of the filter as much as i do for the performance...But ill keep that in mind.
and ttrank..your car is the sexiest thing alive. I dream about it.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
SePa_8310
Sep 16, 2015 04:32 AM
HellaG35
Intake & Exhaust
Sep 8, 2015 10:02 PM
INVADER_6MT
Sep 3, 2015 01:47 AM
