Advice on Plenum spacers
Old Jan 22, 2010 | 01:36 PM
thelarsky's Avatar
Originally Posted by MD website
MREV 2 Manifold:
The Motordyne MREV 2 Manifold is high-torque plenum mod designed for use on any VQ engine.
When used with a 5/16" spacer on the REVUP engine, every test to date shows MREV 2 Manifold will add a "minimum" of 15+ HP and 18+ TQ at 4500 RPM. MREV 2 Manifold is easily the single most effective bolt on modification available for the REVUP VQ engine.
When used with on the non-REVUP engine, the gains are very similar to that of the 5/16" spacer but the MREV 2 Manifold will show a slightly lower peak value, with a slightly higher average value and a slightly higher TQ value. Overall, MREV 2 Manifold provides "area under the curve" and is the highest gain plenum mod available.
The MREV 2 is a actually modified version of the non-revup lower plenum you already have have (netting you a $75 core exchange if you send them yours). Beyond the claims made above, I can't say if it would be worth it for you as I have never driven a non-rev with both MREV and spacer.
Old Jan 22, 2010 | 01:39 PM
SedanManBen's Avatar
Paha, good. Beautiful color by the way on your car. Emerald mist? is that what they call it?
PS i have no idea how to make a custom avatar!
Old Jan 22, 2010 | 01:44 PM
B T's Avatar
B T
strut brace won't fit if you have the 1/2" from what I understand, what led me to go after the 5/16" spacer...
Old Jan 22, 2010 | 01:47 PM
4DGS's Avatar
Yep, Emerald Mist. Thank you (from both swivelhips and myself)
You need to be a premier member to have a custom avatar. You can use one of the stock images though.
Old Jan 22, 2010 | 01:57 PM
Excellent. I guess I'll be looking into ordering the MD copper with iso! From the site it's saying $295 :-\ but i'll do some research.
Thanks for everyone's help
thelarsky's Avatar
Depends on the brace. I bet my GT Spec brace would go over a 1/2" spacer since its height is adjustable. The main concern is usually running the brace AND the engine cover.
Old Jan 22, 2010 | 03:41 PM
SN00P's Avatar
CLUB MODERATOR
i have a 2006 sport 6M/T and i have the rev-up on my car .... and im looking to get a spacer .... so i need to get the 5/16" Motordyne MREV 2??? correct ??and what kind the copper or coolant control valve .. i live in tampa and its always hot and humid out .....thanks for the help everyone
is this what i need ???
Old Jan 23, 2010 | 01:41 AM
Tollboothwilley's Avatar
MREV2 + Spacer for 2005-2006 6MT
Contact Tony at Riverside Infiniti. Tell him you are a member here. He'll give you the best price around probably...for new at least.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
