MD spacer gaskets
Old Aug 24, 2010 | 10:24 PM
the_sedan's Avatar
Question MD spacer gaskets
so i just picked up this MD 5/16" isothermal spacer from this kid today. my Q is that the gasket on one side has a couple spots missing and i obviously need to replace it. can i just scrape that off and use an oem gasket? and he didnt have any of the hardware since he had a V+ plenum on it so i have to order the bolt kit from someone. anyone got a 5/16" spacer bolt kit FS? as far as the gaskets i got an oem one i can use........just wasnt sure what to do exactly since these are kinda glued on the spacer.
Old Aug 25, 2010 | 06:09 AM
Blue Dream's Avatar
I drove ttrank's car solo
You might have to order the bolt kit from Motordyne, they do sell it separately. Just use your OEM gasket on the side with the missing spots and you should be good. Don't try to scrape the MD off, it'll lead to problems you don't want to deal with.
Old Aug 25, 2010 | 08:37 AM
the_sedan's Avatar
its a paper gasket and its literally missing a section out of it. no way it will seal. ill just take it off carefully and use a stock gasket on that side.....maybe with a thin layer of hondabond. any vendors care to chime in and shoot me a price??
Old Aug 25, 2010 | 07:13 PM
LMG_35C's Avatar
Call MD directly. You need to replace the gasket like you're saying. You might consider that the MD gasket (ISO Thermal) is actaully better than the OEM. You definately need the spacers for the center bolts or you will risk cracking the upper plenum. MD's service is great and these parts are not expensive.
Old Aug 25, 2010 | 07:43 PM
OCG35's Avatar
OP, yes you can use your OEM gasket on the side that is missing (earlier versions used OEM on both sides, it will not cause problems) - just carefully remove the remaining portion of the pre-applied gasket being carful not the mar or deform the mating surface. Sealant is not necessary.
As for missing hardware; contact Tony at Motordyne - he is very accommodating and always helpful.
Old Aug 25, 2010 | 08:28 PM
Tollboothwilley's Avatar
Mike, where you been? Haven't seen you around much lately.
Old Aug 25, 2010 | 10:15 PM
OCG35's Avatar
I dont contribute much - for various reasons... still browse occasionally... I logged a few times to reply to PM and a thread response earlier toady - happened to see this thread and decided to reply.
Active members should be happy you are still out here... you are one of the few with good info ~
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Oct 6, 2015 09:31 AM
w4kj4k
Oct 2, 2015 07:57 PM
