Dynoing out the myth of intake mods
Old Dec 13, 2010 | 11:06 AM
  #136
DaveB's Avatar
Originally Posted by boostedforlife
yea good point,
I think id like to see which intake is best after clearing the chock point, the manifold.
The stock intake box and intake tube have been put on a flow bench. The setup can move than air to support a much larger engine. The intake manifold really isn't that much of choking point seeing that at certain rpms it can achive 100%+ volumetric efficency. For a rather simple V6 motor, the intake manifold is pretty trick.
Old Dec 13, 2010 | 06:41 PM
  #137
sexyrob's Avatar
didn't get anything done this weekend, drove down to san antonio for import faceoff with a bunch of the other texas G drivers.
Old Dec 13, 2010 | 07:14 PM
  #138
KingCobra's Avatar
I have a feeling there is either NO results to speak of, or the results are so deceiving that the OP is taking his time to share to build up anticipation
Either way I can guarantee no one here will see "Gained 10hp/15tq from xxx CAI"
Old Dec 14, 2010 | 05:36 PM
  #139
boostedforlife's Avatar
z1 uses cosworth on their 320 whp engine, and those guys been in the game for a long time, so I trust there were some advantages on that over mrev2+ spacer.
Old Dec 14, 2010 | 05:49 PM
  #140
CandlestickPark's Avatar
ill Sedan
I guess it depends on your mods, maybe a fully built NA engine will have gains with the Cosworth. From what I understand the Cosworth loses hp on NA engines.
https://g35driver.com/forums/intake-...yne-setup.html
Old Dec 15, 2010 | 12:42 AM
  #141
Algy's Avatar
Comparing the cosworth was interesting but what about those kinetix ones???
Old Dec 15, 2010 | 12:44 AM
  #142
DaveB's Avatar
If I built a high rev, heavy breathing NA VQ, there's no doubt I too would go with the Cosworth unit. It is better than stock, but the engine has to be able to use it first. The thing is so damn sexy too. Hell, if I had a 6MT with cams, I'd have the Cosworth manifold.
Old Dec 15, 2010 | 01:27 AM
  #143
http://my350z.com/forum/intake-exhau...motordyne.html
Take a look at that, Gabe lost power with that thing, and hes got a 4.15 liter monster.
I am personally thinking about going the ssv velocity, It has been proven to make power on fully bolted on cars, which makes me believe I can make power with that on my built set up.....
The only data missing is it was never tested against a mrev2/spacer.
http://my350z.com/forum/intake-exhau...-de-motor.html
That one looks like the kinetix but has some improvements over it, but there is nothing proven yet.
Here is a dyno that shows a car makes power with the ssv velocity
http://my350z.com/forum/tuning/47093...-velocity.html
Old Dec 16, 2010 | 03:15 PM
  #144
sexyrob's Avatar
write up finished, click here for thread.
Old Dec 16, 2010 | 03:34 PM
  #145
ConradoR's Avatar
Thank You Rob for taking the time to produce such an organized dyno comparison, this will be an asset to many members for years to come.
Regardless of whether crazy discoveries were made or not, (and the members who have looked into this issue were def. not expecting drastic results), we appreciate you going the distance.
Old Dec 18, 2010 | 06:05 PM
  #146
RogerG35's Avatar
Thanks for the write-up!
Old May 31, 2011 | 11:13 AM
  #147
walshtj's Avatar
Good thread.
HellaG35
Intake & Exhaust
Sep 8, 2015 10:02 PM
INVADER_6MT
Sep 3, 2015 01:47 AM
