HR Y-Pipe with Nismo S-tune
Old Aug 19, 2011 | 02:45 AM
.cakestar's Avatar
Hey, Ive been searching for a while trying to find an exact answer but I cant seem to find one. Am I going to run into any trouble if I forgo on the Nismo Y and just keep the Hr Y? I have read about problems with the Nismo and I would actually prefer to keep the lower key tone in the exhaust. Will there be any Issues going from the HR Y to the extension pipe? I just need to make sure I have a gasket and good seal? I am going to use the s-tune mid and muffler, just not the Y. Just so Im clear, the hr outlet is 2.5" while the nismo is 3" correct? I couldnt find the info for the nismo piping but I think i read somewhere that its supposed to be 3". Thats basically where my dilemma comes in, I just want to make sure going from the smaller to the larger piping isnt going to cause any problems.
thanks,
Chris
Old Aug 19, 2011 | 02:54 AM
HenryLee's Avatar
Yea your fine.
Old Aug 19, 2011 | 02:56 AM
lcysimon's Avatar
Howdy Chris,
I asked the same question a while back and went through the same issues with ya.
First of all, Nismo S tune claims 6whp gains...
If you take a look at the HR Y pipe independent dyno, I believe it showed 4-6 whp gain...
So... what does this tell you...?
Yes... the Nismo Y pipe SUCKS.
Don't get me wrong, it sounds really good though.
But at first, I didn't even consider putting on the Nismo Y pipe and went with the HR Y pipe.
No problems at all. Fits perfect and just like stock. However, I felt like it was a bit quiet... Anyhow, I had an Osiris tune and it came out to be 251whp.
About 3 weeks ago, I got tired of the quiet HR Y pipe and picked up a JIC Y pipe which is 2.5" to 3.18". To my suprise... My exhaust sounded the same but just the slightest deeper... However... I did gain a good amount of low end torque based on my butt dyno. Granted, my car was already Osiris tuned, but the JIC Y pipe definately gave more power (especially TQ) from the HR Y pipe.
So, yes the HR Y pipe will work, but you should get an after-market Y pipe that will open the S tune. The S tune is a very quiet exhaust. Under 3k rpm WITHOUT HFC, OEM exhaust is actually louder imo.
Hope this helps
-Simon
Old Aug 19, 2011 | 03:13 AM
.cakestar's Avatar
thanks a lot guys. Really helped me here. I was considering putting the nismo y on to have it all uniform pipe size but I guess ill run with the Hr for now and if I do want to upgrade later ill go with an xyz or something similar. I really just wanted to keep the stock quietness but if your saying even with an aftermarket Y it will still be relatively soft I might just go that direction. just dont want any drone when cruising on the fwy.... or unnecessary attention from the authorities lol
Old Aug 19, 2011 | 03:36 AM
Algy's Avatar
my s-tune y-pipe had a leak in it, so I changed it out for the m2performance hr y-pipe. its a 2.5 inlet to a 3.0 outlet. matches up perfectly and made the exhaust louder. i had the regular hr y-pipe and yes it makes the exhaust quieter. with the original s-tune y-pipe it would be louder vs the oem hr y-pipe.
here is a link to the pipe
https://g35driver.com/forums/intake-...gn-y-pipe.html
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
