i just swapped my mrev2, 5/16 spacer, polished plenum, and polished throttlebody for the oem setup. i did the install corectly and when i went to turn on my car my engine cranks but it wont turn over. does anyone have any idea whats wrong?????
Z1Motorsports
close
- Join DateJan 2007
- LocationCarrollton, GA
iTrader Positive Feedback100
iTrader Feedback Score(8)
Liked:69 Times in 55 Posts
Quote:
Do you mean it spins over but wont crank? Did you reconnect the TB? Originally Posted by heythatsneat
-Rob
yeah i plugged both in. does the throttle body go "bad"? i bought it used.
Z1Motorsports
close
- Join DateJan 2007
Quote:
Yes TB failure is pretty common, you can attempt an idle air relearn but most of the time miscalibration will cause rough idle, stalling but will allow it to start. Since its used i'd bet its a bad TB, swap the old one back and atleast try it. Originally Posted by heythatsneat
-Rob
Z1Motorsports
close
- Join DateJan 2007
Also to test the TB before removing it you can, Remove the Intake, Turn the key to the ON position, put the car in 1st if MT and D if AT, and press the gas pedal and have a friend see if the blade moves.
-Rob
-Rob
Quote:
-Rob
the TB blade is moving when i go from the "on" to "off" positions.Originally Posted by Z1Motorsports
Also to test the TB before removing it you can, Remove the Intake, Turn the key to the ON position, put the car in 1st if MT and D if AT, and press the gas pedal and have a friend see if the blade moves.-Rob
Z1Motorsports
close
- Join DateJan 2007
Quote:
Thats a good sign but you still need to check to see if its moving when the pedal is depressed. You best bet is going to be through back in the stocker and see if it runs.Originally Posted by heythatsneat
-Rob
