Berk HFC + ARK DTS Exhaust
Old Nov 4, 2011 | 02:39 PM
SuperCleanG's Avatar
I know this subject has been beaten to death and most of the information people need regarding HFC's can be found on this site, however I still need some advice.
First, if anyone has this set-up please let me know how you got rid of hiss and the rasp.
I understand that this is usually inevitable depending on your exhaust. A true dual setup should take care of alot of the annoying side effect of the install. If that does not help I understand an X pipe should take care of the rest.
My issue is that my set -up is similar to the OEM set-up
I cant utilze the x-pipe and at this point am pretty annoyed from the sound.. Car drives awesome but sound like sheet between the normal range of rasp ( 3000rpms).
Anyone have any suggestion so that I dont have to spend another G on exhaust.
Old Nov 4, 2011 | 06:35 PM
Also the piping is 2.5 inches
Old Nov 11, 2011 | 12:49 PM
Can I get some feedback on this fellas?
Old Nov 11, 2011 | 01:18 PM
Jairen's Avatar
Looks like it has a standard size y-pipe? Why not switch to the Motordyne XYZ Y-pipe with resonator?
A much cheaper alternative is to simply replace that resonator in the mid-pipe with a more effective resonator or even another muffler in it's place. Any shop could do that.
Old Nov 11, 2011 | 09:13 PM
What do you think about using this and just cutting the existing mid pipe and welding it in?
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
DRG35R
Sep 16, 2015 05:33 AM
