longer piping the better?
Old Dec 4, 2011 | 04:58 AM
whoisthis's Avatar
i read from somewhere that for N/A cars, it's better to have the exhaust piping long. for example, making loops here and there before exiting the bumper hole.
Is this true? i'm planning to use stock midpipe, convert to 3" piping, go around the rear diff and exit to the passenger side bumper hole.
i have a 3" custom y-pipe back exhaust with a resonator which sits low on the ground, and loud for me.
please enlighten me with how the exhaust back pressure works..
Old Dec 4, 2011 | 08:57 AM
Texasscout's Avatar
The thing you want to control is back pressure. In a NA (normally aspirated, non-forced induction) motor, the amount of back pressure can be used to control the torque "hump", as it were. Less back pressure moves the hump higher in the RPM band, more moves it down the band etc.
In a FI car, the less BP the better. Lower BP will get you the same HP with less manifold pressure.
As for "longer exhaust", no, you shouldn't add "curves" to the exhaust, each curve adds more restriction. What you may be thinking of is "long tube" headers. They are very good at getting that last bit of HP out of a NA motor. The only problem with them is you lose your CATs.
Even with the stock mid pipe, without a rear muffler, it will still be loud and raspy.
Old Dec 4, 2011 | 09:30 PM
whoisthis's Avatar
i've been driving around with only stock cats. crazy loud, and won't give good torque.
now i put back my 3" custom single, it's so quiet lol.
Would the loudness of only cats be same as, cats+stock y pipe+ bottleneck resonator+ 3" piping all the way out?
my end muffler interferes with rear bumper so i'll have to cut that muffler off (which is what i was gonna do any ways.)
Old Dec 5, 2011 | 12:30 AM
Xet's Avatar
Xet
loops??!?! can't tell if srs or troll..
Old Dec 5, 2011 | 12:37 AM
whoisthis's Avatar
recently, aftermarket exhaust came out for GTR(?) which costs nearly 10K. It got some serious loops(?), well extra piping where not necessary i guess.
Old Dec 5, 2011 | 12:46 AM
Sylvan lake V35's Avatar
It might be done to help accommodate mufflers in a tight space, like the rear of a GTR.
Old Dec 5, 2011 | 02:41 AM
Xet's Avatar
Xet
which exhaust? if you mean something like amuse that isn't performance based really. and some exhaust components have different components such as ART test pipes that help sound/performance, but they aren't loops
Old Dec 6, 2011 | 12:07 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
You don't have to sacrifice cats for long tube headers, you can run the XYZ pipe with the HFC attachment and then run whatever combo of midpipe and axleback
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
vamarris
Sep 26, 2015 12:56 PM
