cat O2 sensor removal
Old Mar 30, 2012 | 01:10 PM
g35sweetness's Avatar
i am tryin to remove the cat sensors completely at both end but how do you get the other end (clip end) out? this is just a trivial thing but i just cant remove it.. is there a trick?
Old Mar 30, 2012 | 01:12 PM
Songle6MT's Avatar
Push in the little pin that holds the clip in place to get the connector off. Then all you do is slide it off the post.
I used a little screwdriver to push the pin in because my fingers couldn't do it lol. Just takes light pressure.
Hope that helps.
Old Mar 30, 2012 | 01:14 PM
ok i will try that, thanx
hey i have to run my coupe for several weeks without O2 sensors, them completely off so do you think it will be ok? no limp mode right?
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
Eomfd
Aug 29, 2015 12:42 AM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
Gsedan35
Jul 25, 2004 04:21 PM
GlenRoseFireFighter
20
Jun 3, 2004 06:09 PM
