So I'm getting an aftermarket (ebay) y-pipe from a buddy for dirt cheap. I believe it has a 2.5" inlet and a 3" outlet (will measure when I get it). Looks just like this megan pipe:
http://www.ebay.com/itm/Nissan-350Z-...7d462d&vxp=mtr
I searched and cannot find out if the 3" outlet will bolt directly to my stock mid-pipe, which I think is 2.5 inches. And will it bolt up to the stock cats? Just looking for a little more sound. Will probably get high flow cats and the rest of the exhaust eventually.
Blue Dream
I drove ttrank's car solo
close
- Join DateMar 2009
- LocationBy the sea, Tx
iTrader Positive Feedback100
iTrader Feedback Score(50)
- My RideG35 sedan w/ too much money in mods
Liked:1,488 Times in 1,223 Posts
It will bolt up just fine, just be prepared for some rasp to develop due to the different piping sizes.
SAMzG35
close
- Join DateOct 2011
- LocationFort crack homie, AB
iTrader Feedback Score(5)
- My RideG35
Liked:260 Times in 210 Posts
I have FI HFCs. What's a good Y pipe to bolt on stock exhaust? My flex pipes are cracked and need to be replaced.
I might buy a Nismo S tune but its missing the Y pipe anyways.
SAMzG35
close
- Join DateOct 2011
- My RideG35
Anyone?
What Y pipe do you recommend for bolting on stock?
Or any idea wheres the best place to pick up a Nismo S tune?
^I doubt there is really much of a difference in y-pipes. They aren't going to make a lot of power anyway. Just get a stainless one with the right size piping, inlets, etc. If you have the cash buy name brand like motordyne. Keep in mind if you are slammed the y-pipe will more than likely take a beating, so you might not want to pay too much if it's not going to last forever.
Just an update on this. The y-pipe made zero noise difference in the stock exhaust. Maybe just a hair louder, but it was probably in my head. Once I added a full exhaust it became really loud...
Originally Posted by SAMzG35
Anyone?What Y pipe do you recommend for bolting on stock?
For a stock exhaust, you should look into getting an HR style y-pipe. The design is different from the DE y-pipe.
There are lots of positive feed back from these y-pipes. I believe there is a thread floating around with a guy that got the HR y-pipe dynoed compared to the stock DE y-pipe.
As for the Nismo, just check out the market<private<exhaust section and you should find one use for roughly 5-700 hundred.
^this, if you are using stock exhaust go with hr y pipe, not only does it make it a little deeper, its dyno proven to add some power. if you are going to go with nismo s-tune later, id recommend the xyz pipe or you can use that megan pipe as the outlet will be 3" and match up well and will avoid any extra turbulence in the exhaust gasses.
I know megan also makes a 3'' outlet style hr y-pipe that you could be pair up with a nismo.
I used M2 performance 3'' hr y-pipe when I had a nismo.
ItsA..Gthing
close
- Join DateNov 2012
- LocationN.C
iTrader Feedback Score(13)
Liked:218 Times in 187 Posts
Did you guys ever figure out which Y-Pipe is best for stock exhaust and HFC combo..Was leaning towards HR y-pipe or megan...
SAMzG35
close
- Join DateOct 2011
- My RideG35
Im running Megan racing HR style Y pipe along with FI HFCs. It sounds good, barely any rasp just a bit on higher rpm when the car is cold. After that it disappears.
Sound wise, sounds totally stock. Maybe a little louder/deeper.
Frankieg35
close
- Join DateOct 2006
- LocationSouth Jersey
iTrader Positive Feedback98
iTrader Feedback Score(41)
Liked:857 Times in 745 Posts
What about a motordyne xyz pipe with straight pipe or resonator for the s-tune?? Is it the same size piping??
