simpler y-pipe**b-pipe fix
Old Jan 29, 2005 | 01:59 PM
MOTOP's Avatar
Originally Posted by jasperg35
do you think he is willing to make a few more for distribution? i can almost smell a group buy coming on.
I told him that I'll post this on the forum and he might be getting more calls about this, but I never discussed any discounts or anything like that. After all my whole cat-back exhaust with stock muffler will net me less than $400 including labor.
Old Jan 29, 2005 | 02:01 PM
MOTOP's Avatar
just echoing crazymike - is the extra flange a 'non-issue' to the overall length? i imagine there should be enough play with the fujitsubo style y-pipe because of it's flex sections. just checking to be sure.
All you have to do is make proper measurements before cutting of the stock flange and replacing it with reducer cone.
Old Jan 29, 2005 | 06:29 PM
baileyrx's Avatar
Any y-pipe with a 3in outlet, could benefit from this. Our stock b-pipe in only 2.5in. At midas the tech just held up the flange & reducer cone combo. the made a mark ~ 1/2 short, he then cut the pipe with a "choker" type pipe cutter. The end of the b-pipe just snapped off. Then he simply welded it on. I kept the end of the b-pipe just in case. Glad ya'all like it.
-JIM
Old Jan 30, 2005 | 01:20 AM
MOTOP's Avatar
baileyrx,
Did you polish the welds on the inside?
Old Jan 30, 2005 | 09:29 AM
baileyrx's Avatar
no i didn't
Old Jan 30, 2005 | 09:45 AM
jaspergtr's Avatar
sorry dude. i wasn't asking for discounts, just the quantity. that should make my request more reasonable. just wanted to see if i'd be able to my hands on this.
Old Feb 21, 2005 | 03:24 PM
copbait's Avatar
Great post, I just ordered one from Chuck @ Dr Gas for $35. Definitely a better solution than a replacement b-pipe!
Old Feb 28, 2005 | 09:42 PM
copbait's Avatar
Just had this put on by my local muffler guy, and am very happy with the results. Cleaned up the sound under throttle above 4k and eliminated some strange noises at WOT which were probably due to turbulence. Definitely the way to go
Old Mar 11, 2005 | 11:42 AM
Brando's Avatar
Just curious....what did your muffler shop charge you to install and weld????
I just ordered mine from Dr Gas also.
Old Mar 11, 2005 | 03:58 PM
deviant1's Avatar
copbait: How does the exhaust sound with the mods you've done?
I have a Gruppe-S Y-pipe installed, and Helix Hi Flow cats waiting to go on once it warms up here, and am contemplating doing a similar reducer instead of an expensive Y-pipe back exhaust.
Any way you could get a sound clip of your car??
Old Mar 15, 2005 | 08:44 PM
Paragon's Avatar
I installed the UT Y-Pipe over the weekend.
I ordered the flange (2 hole, 4.5" between hole centers and reducer cone 3" --> 2.5") from Chuck at Dr. Gas, welded, for $35 (+ shipping) as others had mentioned in this post.
I pulled out the mid-pipe and took it along with the reducer cone to a muffler shop.
Definitely call around when looking for someone to weld the reducer cone to your mid-pipe. Two different Midas shops quoted me $58 and $20. Meineke said I would have to make an appointment to do what they considered "custom" work and it would take a few days (WTF?!). I finally found a small private muffler shop that took 10 minutes to do the job for me for $10.
Make sure the shop aligns the flange in the same position as the stock one before they weld it on. The shop chalked the position, but my alignment was still off a bit....fortunately managed to bolt it up with a bit of manipulating.
Here's a sound clip <a href = "http://home.comcast.net/~reynold49/Stock.mp3" target="_blank">before</a> and <a href = "http://home.comcast.net/~reynold49/UT.mp3">after</a> installation of the Y-Pipe...exhaust note sounds deeper. Note my other mods before the Y-pipe install were Motordyne 3/8" spacer, Z-Tube and K&N drop in.
I plan to upgrade to a Fuji exhaust down the road, but for now, I'm happy with this setup!
Paragon
Old Mar 15, 2005 | 11:19 PM
copbait's Avatar
My welder did the job for $30 without taking anything off the car. Took him 15 minutes to saw off the old piece and weld on the new one.
Old Mar 15, 2005 | 11:22 PM
copbait's Avatar
I'm very happy with the sound. The cats and ypipe really added some low end growl when under hard throttle. While cruising it's about as quiet as stock, with no highway drone at all.
The stock exhaust is supposed to be as free flowing as it gets, so I saw no need to replace it because I am happy with the sound. Great setup!
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
NyCrAzY
Oct 1, 2015 09:19 AM
