Has anyone successfully eliminate hissing/rasping from test pipes?
Old Nov 17, 2012 | 02:02 PM
canehdian_guy's Avatar
Has anyone successfully eliminated the hissing/rasping noise from test pipes without changing their exhaust system too?
I've heard replacing the y pipe can help but I'm not too sure how reputable the source was.
Thanks
Old Nov 17, 2012 | 03:55 PM
Eno's Avatar
Eno
Check out this thread:
https://g35driver.com/forums/intake-...-2003-g35.html
I don't have much experience with that mod but there is loads of discussion on the subject over in the exhaust forum.
Old Nov 17, 2012 | 06:58 PM
gary c's Avatar
Solution is simple, sell your test pipes to some unsuspecting member looking to do cheap mods to his G and get HFCs or ART pipes! Great sound costs $$ remember you get what you pay for....Gary
Old Nov 17, 2012 | 08:27 PM
Fortunately I didn't jump the gun on the purchase just trying to do "cheap mods"...should've learned from the plasti dip
Old Nov 18, 2012 | 01:10 AM
Herbbie Hablib's Avatar
How are the resonated test pipes? Still raspy? After watching the Art pipe before and after vids they didnt do **** still has the civic coffee can effect.
Old Nov 18, 2012 | 06:18 PM
Sorry I missed that so ART pipes don't create rasping? Are they pretty easy to install and wouldl they work with a fast intentions exhaust? Do these cause the CEL to come on?
Thanks
Old Nov 18, 2012 | 06:44 PM
yosip1115's Avatar
AAM HFC's with a M2 Y pipe still rasp a bit, but do it right and your like the Z in F&F 5. It's almost impossible to avoid with HFC's, forget test pipes! Stick with HFC's and even then, be careful because the cheap ones sound too tin can like.
Old Nov 19, 2012 | 01:59 PM
I was worried about that definitely don't want a fart can exhaust. I had previously considered hfc's until I heard reports of them failing around 20-30k miles, can anyone verify this?
Old Nov 19, 2012 | 02:49 PM
jstudrawa's Avatar
Gary, you're a stand-up guy. No need to suggest this.
There has to be high-heat sound-deadening material that can take the rasp out, it's only a vibration right?
http://www.koolmat.com/
Would something like this, in theory, work? Re-read the description, it's sound deadening from the stand point that sound doesn't go THRU it, it doesn't absorb it. There HAS to be a way to absorb the vibration. Does anyone know the frequencies involved at all?
Old Nov 19, 2012 | 11:04 PM
Junkanoo's Avatar
I heard a HKS rep with HFC's and a magnaflow x pipe installed in place of the resonators and it had a deep tone throughout all the gears.
Old Nov 20, 2012 | 11:39 AM
rsingerG35's Avatar
What are test pipes?
Old Nov 26, 2012 | 06:31 PM
Test pipes eliminate your catalytic converters. For anyone who views this in the future apparently after the Motordyne ART pipes are broken in you will no longer here a rasp. When it comes to installing the ART pipes request that the mechanic cuts off the bolt on the drivers side of the heat shield or else there will be a rattling sound.
Buyers beware though, catalytic deletes are going to be nice and stinky.
Old Nov 27, 2012 | 12:32 AM
SAMzG35's Avatar
G35
I'm running FI HFC along with Megan Y HR style. ( . ) ( . )
Old Nov 28, 2012 | 02:17 PM
dj714's Avatar
Question
Ya my buddy hooked me up with his Berk HFC that he blew with in a couple miles. One of the HFC is missing about half of the honeycomb looking inners and they other is complete but when you shake it in a front to back motion you can feel a slight movement in the honeycomb inners.
Question
1. can this be fixed (not sure if its even worth it)
2. Should I knock out the same amount of honeycomb in the good HFC and just roll with it.(would this create rasp and Cel issues)
Old Nov 28, 2012 | 02:34 PM
SAMzG35's Avatar
G35
pretty sure that would set a CEL
