Help on picking a intake
Old Mar 30, 2013 | 09:42 PM
Gummy951's Avatar
I have a 03 g35 6MT and im looking to put a intake but am not to sure on what to get. Any help please????
Old Mar 30, 2013 | 09:47 PM
dukehotty's Avatar
Since adding a different intake will not give you any power gains, you should just pick what you think looks and sounds good. Check some youtube clips for different sound options. You can also check this forum's marketplace to find good deals on a used intake from other members.
Old Mar 30, 2013 | 09:52 PM
Kerry Garrison's Avatar
If you are going for bling, than a pop charger or cold air intake (CAI). If you are going for functionality, than a K&N drop-in filter.
Most of the replacement intake systems suffer from being too close to the engine and they end up sucking in hot air, making them less efficient.
A CAI system will locate the filter as far away from the engine as possible to avoid hot air. However, avoid the ones that put the filter near the bottom of the engine. First off, the asphalt is much hotter closer to the ground and you run the risk of water getting into it.
My suggestion is the K&N drop in filter. You get better airflow than stock, its re-usable, saving you money in the long run, and works well.
Old Mar 31, 2013 | 07:07 PM
Gummy951's Avatar
Thnx ill let you know what i end up getting
Old Apr 1, 2013 | 03:50 PM
B FIFE22's Avatar
The R2C intake is another good option as well. It comes with a heat shield that seals against the hood and sounds and looks great.
Old Apr 1, 2013 | 03:59 PM
Peoria35sedan's Avatar
R2C, Stillen or Z-tube with a Revup air box are the only ones that wont heat soak. You can also find silicone intakes from Samco and Cobb instead of he Z-tube.
unvmyg's Avatar
I have an takeda intake uses stock airbox. Hit me up for details.
Old Apr 2, 2013 | 08:48 PM
Gummy951's Avatar
Can u pm me pics? What about a z tube with a hks exhaust will that pass smog legally?
Old Apr 9, 2013 | 04:26 PM
Lartytiejdke3's Avatar
That's what I have and I love it but I'm in jersey so no smog
Old Apr 9, 2013 | 05:56 PM
No smog tester is going to fail a Z Tube as you would REALLY have to know what you are looking for and since its stock on a 350Z, I doubt it would be an issue anyway. Any drop-in filter like a K&N will pass since it still looks stock. A rev-up box would only be noticed by someone that really knows the engine. As soon as you remove the box and go to an expose air filter that is almost always an automatic fail.
In California, so long as you have catakytc converters still in place, and you pass emissions, the exhaust should be fine.
Old Apr 12, 2013 | 02:53 AM
JizZLe23's Avatar
Jwt pop charger with z tube
Daniel k.
Nov 3, 2015 09:52 AM
G35VSHNG37
Oct 25, 2015 08:43 PM
IEMaestro
2nd Gen (V36) Sedan
Oct 22, 2015 09:09 AM
imRACERX
19 Inch
Sep 10, 2015 08:53 AM
1OG35
Aug 7, 2015 11:25 AM
