Help! Y-PIPE
Old May 24, 2005 | 06:57 PM
PhxBlue's Avatar
Polyester Pileup FTW!
Originally Posted by Dan_K
I heard that Tanabe is releasing a new Y-Pipe that will increase airflow and work with our 2.5" midpipe.
This is the only Tanabe Y-pipe I could find. It says the outlet is 70mm. Does that convert to 2.5 inches?
Old May 25, 2005 | 02:54 AM
WRX2G35's Avatar
Former G35 Driver
Just divide by 25.4 to get inches, so 70mm is approximately 2.76 inches.
Old May 25, 2005 | 03:06 AM
PhxBlue's Avatar
Ok , so the Tanabe pipe pictured above is a very close fit to the stock mid pipe.
Old Apr 25, 2006 | 10:38 AM
JEVERYDAY's Avatar
Great thread! Thanx SI_G35Coupe for the info
Old Apr 25, 2006 | 10:55 AM
gary c's Avatar
New y-pipe............
I've had my new y-pipe on for several weeks now
along with the new cat-back system. I searched
and talked to several people but ended up with a
Top Speed y-pipe. It's all 2 1/2" into a 3" collector,
totally polished and looks like a showcar piece.
Like everyone in the know says, "it bolts on"!!!!!
Delivery was quick and the price was good, located
on this site under exhaust........LOL.
Old Apr 25, 2006 | 03:20 PM
OC 350GTCoupe's Avatar
The Tanabe Y Pipe is out, it has 60MM inlets, and a 70mm outlet. It's pretty much the smallest diameter Y Pipe available besides the Kinetix Y Pipe. (I dont even think Kinetix makes it anymore)
If it's true that the stock exhaust is 2.5 inches that = 63.5MM.
High Flow cats are 2.25 (57MM).
My headers are (55MM).
So, if your keeping your stock exhaust, you might want to get a custom built Y Pipe, something with like 58mm inlets, and a 63MM outlet.
If your going to get a aftermarket exhaust, like a Fujitsubo (76MM), then make sure you get a Y Pipe with outlets equal to or smaller then 76MM.
As for me, i already have headers and cats in the garage waiting to be installed. But i wont install them until i have aftermarket y pipe and exhaust.
My setup will be like this:
The headers are 55mm, connected to high flow cats that are 57mm on both ends, connected to what will be the Tanabe Y Pipe with 60MM inlets, and a 70MM outlet, and a Fujitsubo exhaust with a 76mm diameter.
So thats, 55mm to 57MM, to 60MM, to 70MM, to 76MM.
Old Apr 25, 2006 | 03:49 PM
99atlantic's Avatar
hope you don't end up cracking your cats because of it
Old Apr 25, 2006 | 05:00 PM
Yep, its just 1/4 inch (6.5MM) bigger then stock midpipe.
In fact, i thought i read the stock mid pipe was 2.5 diameter, but with a 2.75 inch flange.
Old Apr 25, 2006 | 05:37 PM
The HKS Y Pipe goes from 2.36 Inch inlets, to a 2.55 inch Outlet. That would mate well with Hi Flow Cats (2.25 inches) and the stock exhaust (2.5 inches).
HKS Y Pipe is kinda pricey tho at $470.
HKS Y Pipe (2.36 inlets to 2.55 outlet) ($470)
Stock Y Pipe. (Dont know diameter)
Tanabe Y Pipe (2.36 inlets to 2.75 outlet) ($370)
Old May 3, 2006 | 05:35 PM
ppw350Zunit's Avatar
anyone know where to purchase an hks y-pipe?!?!
Old May 4, 2006 | 12:55 AM
rkang915's Avatar
Quick Question megan y pipe
Does the megan y pipe fits the fujitsubo exhaust? Any problem with this setup. I just feel that fuji y pipe is way too expensive, i know that the quality is good but i dont think is worth the price. Any problem with the megan y pipe?? Help thanks
Old May 4, 2006 | 11:42 AM
GT-Ron's Avatar
I know the Fujitsubo is 3" Y-pipe. What's the diameter of the stock mid-pipe? I am guessing its smaller than 3", so I was wondering how well the y-pipe will fit without any leaks, since you are connecting a smaller midpipe opening to a bigger y-pipe opening.
Wouldn't there be a lot of pressure on the gasket?
As others may have mentioned, a reducer cone solves this.
I have a NEW, never-installed, NISMO Y-pipe with new Dr. Gas reducer cone (for use with the Y-pipe with the stock rear-section exhaust) for $400 SHIPPED if interested. These are two individual pieces, neither of which has ever been used.
-Ron
Old May 4, 2006 | 01:27 PM
http://www.hopupracing.com/hksypini35in.html
Danielek
May 1, 2022 01:28 PM
Video Share
Jan 31, 2017 04:00 PM
Moskvitch
Sep 14, 2015 10:15 AM
kevintandmd
Sep 3, 2015 06:41 PM
