Crawford Cats/Y Pipe Combo
Old Aug 7, 2005 | 12:55 PM
dgbos4's Avatar
I have searched the posts and this seems to be a good combo. I already have the plenum spacer, z tube/K&N.
I am trying to determine what else I need to ensure the Y pipe connects to the stock exhaust properly. From what I have seen the aftermarket Y Pipes have a 76mm outlet while the stock is 65mm - what have others done to make sure this fits right? Is there a gasket to buy?
I still haven't decided if the JIC & Fujitsubo are worth the extra $$ over Gruppe or Unlimited.
Old Aug 7, 2005 | 07:25 PM
LMG_35C's Avatar
If you plan to eventually get an after-market exhaust then I'd suggest looking into a reducer for matching these larger y-pipes to your stock mid-pipe (do a search for it in this forum).
If you intend to keep stock exhaust then the Tanabe or Kinetix Y-pipes might be the way to go because they are 70mm and will provide better match to the stock exhaust...
...go for it!
Old Aug 7, 2005 | 07:35 PM
dgbos4's Avatar
Thanks - I plan on keeping the stock exhaust for awhile. It seems as though the most restrictive parts are the cats and Y pipe so I am not going to do the exhaust. I will check out those 2 if they match up to the stock better.
Old Aug 8, 2005 | 01:42 AM
DannoG35's Avatar
If you go with the aftermarket exhaust what is your concerns for getting Fugitsubo or JIC? I am just interested in why you chose those 2. I personally want the Fujitsubo exhaust, I love the look and sound.
Old Aug 9, 2005 | 09:58 AM
dgbos4's Avatar
I was referring to Fujitsubo or JIC for the Y pipe not exhaust. They are much higher $$ than gruppe or unlimited. I am keeping the stock exhaust and just swapping the cats and y pipe.
btw, I have read nothing but good things about the Fujitsubo exhaust.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
