Borla Drone Fix
Old Oct 10, 2005 | 07:10 PM
Vancouver_G35's Avatar
Borla Drone Fix
For those of you thinking about or have already installed a Borla True Dual for the sedan, I thought I'd let you know that drone can be toned down a bit. Although I have not seen many posts about drone on the Borla. I found it somewhat annoying right around 2000 rpm which is street or freeway cruising RPMs. I called Borla and they offered to send me two venturi tubes. They look like little spools and effectively act as constrictors. To install them you need to take apart the exhaust and tac-weld the pieces into the piping near where you think the droning sounds the loudest. In my case I felt the front muffler, the one right after the cats, was the noisiest. So I was told to install them in the outlets of that muffler.
2 hours of labor later, I did find a noticeable improvement to the droning and now, low rpm cruising is much better. If you are having similar problems, give Borla customer support department a call and they will send you the parts for free.
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
NyCrAzY
Oct 1, 2015 09:19 AM
