Stillen CAI Install Question
Old Jul 30, 2003 | 09:55 PM
G354Door's Avatar
Hi,
My Stillen CAI is due to arrive tomorrow. Just wanted to here from those that have installed one. Does it have a good set of instructions and if there are any special tools I will need?
Thanks,
John
Lovin' my G
Old Jul 31, 2003 | 01:21 AM
pratG35's Avatar
Re: Stillen CAI Install Question
John,
The bolt at the bottom of the CAI unit under the air filter is a little difficult if you have large forearm. However the box (well not really a full box) is flexible that you can squeeze in there. Personally the box look flimsy but once installed is pretty secured. It will be nice if you have 3/8" drive rachet with I believe 10mm socket. A wrench will work also but rachet is faster. Don't forget to leave the battery unplugged (negative end) for 12 hours so your ECU will learn about your new CAI and fully take advantage of it.
You will love it!
-PratG35
Silver 2003.5 G35 Sedan 5AT / Sports and premium package
Stillen CAI / 6 Wire grounding / Battery Quick Disconnect Switch
Stillen dual exhaust (when it comes out)
Eibach Pro Kit (soon..)
350Z Intake Duct (soon..)
Old Jul 31, 2003 | 01:41 AM
wreck's Avatar
Running for his life!!
It comes with instructions. The bolt on the bottom I left out. I just couldn't reach down there. Also you will need a drill bit. My didn't come pre-drilled. I don't know if it does or not.
G35C 6MT / AMG E55
Old Jul 31, 2003 | 09:10 AM
G354Door's Avatar
Thanks for the info. I am looking forward to installing it.
John
Lovin' my G
Old Jul 31, 2003 | 09:11 AM
G354Door's Avatar
Thanks for the input. What did you have to drill? Do you remember what size drill bit?
Regards,
John
Lovin' my G
Old Jul 31, 2003 | 09:45 AM
Dabearz454's Avatar
i didnt need a drill. the tools are minimal, dun worry bro the directions that they give you are really good its no sweat, you will be in and out of there in a half an hour.
Old Aug 8, 2003 | 04:16 PM
808HerbzG35's Avatar
Did anyone remove the protective screen in front of the MAF/sensor before installing Stillen Hi-Flow CAI? Thanks
Old Aug 8, 2003 | 08:57 PM
mbarrad's Avatar
I left mine there. Looks like it protects the motor and doesn't look too restrictive.
Old Aug 9, 2003 | 09:30 AM
cato's Avatar
SouthernComfort Moderator
Mike,
Did you install the 350Z duct first without your
StillenCAI? If so, what were your impressions
of adding the Stillen CAI afterwards? Do you
think I will really gain more HP with the addition
of the Stillen CAI? I'm fence sitting right now as
to what to do next.
2003 Twilight Blue Sedan 5AT, sunroof, leather,
splashguards, GG red 7 wire Hypergrounding kit, 350Z intake duct, K&N filter.
Old Aug 10, 2003 | 10:47 PM
mbarrad's Avatar
I installed the Stillen box first and then the Z-Pipe. Did not notice much if any power gains. I did gain a better feeling of the engine though. Hope that helps.
EPG35
Aug 16, 2015 04:52 PM
Team STILLEN
Aug 10, 2015 08:17 PM
Racova
2nd Gen (V36) Sedan
Aug 8, 2015 10:21 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
